Transmission "Chatter"
Old Jul 6, 2021 | 08:42 PM
  #46
raytasch's Avatar
raytasch
Believe Nothing
""Still has some vibrations as it picks up speed in first, but..............it's getting better."
The above statement tells me you have other than a clutch problem. As the vehicle picks up speed the clutch has already engaged so should not be slipping if correctly adjusted so no chance of chatter. Or is this semantics? Has anyone jacked that truck up, put it in neutral, and rotated the driveshaft feeling for roughness in the driveline?
A bad U joint or rear end problem will cause the problem you describe.
Old Aug 9, 2022 | 09:49 PM
  #47
pagoda69's Avatar
pagoda69
Well, problem fixed. Flywheel was never resurfaced when the clutch was replaced. Fist and second mechanics failed to do the job, and, both were less than truthful, telling me that the flywheel was resurfaced. Found a local father/son mechanics who specialize in 50's and 60's cars/trucks. They did a great job. Shifts smoothly now. A pleasure to drive again!
Old Aug 10, 2022 | 07:00 AM
  #48
mechmagcn's Avatar
mechmagcn
Glad you were finally able to get the problem solved.
CJ McGee
Sep 26, 2019 07:19 PM
slabhunter
Jul 16, 2018 05:11 PM
ige1963
Jan 25, 2015 10:23 AM
BuckHammer
26
Jul 27, 2012 10:45 AM
jowilker
May 19, 2000 07:42 AM
