Balancer question
Old Jun 16, 2021 | 08:39 AM
wrongway01's Avatar
wrongway01
Balancer question
I have a 96 351 Windsor auto truck. I'm building a new engine for it and I would like to replace the balancer with something a little newer and nicer. Problem is I have the reluctor wheel pressed on my stock one that checks for misfires. If I unplug the sensor I get a CEL for random misfire. I have not found any newer ones with this reluctor wheel (crank trigger) or whatever you call it. Does anyone know if you can defeat the sensor, or can the wheel be transferred to the newer balancer? Thanks
Old Jun 16, 2021 | 09:33 AM
GoinBoarding's Avatar
GoinBoarding
Whatever you do, hold onto the original.. this is a one year part, I've never found a source for new.
Old Jun 16, 2021 | 09:49 AM
rla2005's Avatar
rla2005
You may be able to use a tuner to shut off the misfire detector code, but I have no first hand experience. There was a recent thread on the same topic where the OP was trying to get in touch with Damper Dr.(sp?) but got no response. These one year only balancers are rare. Take yours to a machine shop to see if they replicate the stator to mount on a new balancer.
Either path is going to take some detective work.
Axle1962
2009 - 2014 F150
May 18, 2018 07:14 PM
droppedf100
Dec 19, 2013 01:48 PM
brobrad
1997 - 2003 F150
Jan 22, 2013 07:52 PM
92lx
Jun 19, 2006 02:59 PM
