Gotta fixum all... Deep in the red with E99 problems
Old Aug 4, 2021 | 07:42 PM
  #256
Ezalycasaid's Avatar
Ezalycasaid
Originally Posted by Walleye Hunter
I thought that the only wiring difference between E and L 99 would be for the intake air heater, if even that is different.
I really hope you're right.
Old Aug 4, 2021 | 07:56 PM
  #257
ESwift's Avatar
ESwift
CNCFAB
The aih is the only difference on the engine harnes
E99-L99
Old Aug 4, 2021 | 07:59 PM
  #258
FordTruckNoob's Avatar
FordTruckNoob
So…… you’ve got E99 problems and a L99 (engine) is one of them?
Old Aug 4, 2021 | 08:10 PM
  #259
PriusLover's Avatar
PriusLover
I don't think the L99 engine has any additional sensors vs the E99. Only thing the E99 PCM can't do is turn on the AIH, or PWM the torque converter.
That being said, an E99 PCM wont be programmed to handle L99 injector sizes or the long lead #8 I think.
  #260
HAHA sounds like it buddy.
Old Aug 4, 2021 | 08:14 PM
  #261
Walleye Hunter's Avatar
Walleye Hunter
What is 'PWM the torque converter'? And I have not heard that the injector size difference was an issue. I thought that certain PCM's were fully interchangeable with the AB injectors and that the AD's could be installed with no changes in PCM or IDM.
Old Aug 4, 2021 | 08:27 PM
  #262
RacinJasonWV's Avatar
RacinJasonWV
Pretty sure I’ve read that the injector size is not an issue. But hopefully an expert will chime in.
Old Aug 4, 2021 | 08:28 PM
  #263
The other question is, did they change the E99 injectors into the L99 motor?? Because all the injectors are out of the E99 and there's a box of injectors with it. But idk if those injectors are the E99 or the L99. How can I tell?
  #264
PriusLover's Avatar
PriusLover
Locking the torque converter via PWM vs an on/off signal.
Some googling suggests that AD injectors can run fine on a E99 pcm and idm, I stand corrected.
AB injectors should say "AB" on them.
Old Aug 4, 2021 | 08:36 PM
  #265
Walleye Hunter
E's have 'AB' on the tops of them and the others have 'AD' on them.
Old Aug 4, 2021 | 08:46 PM
  #266
Ezalycasaid
So wich injectors do I want in there?
Old Aug 4, 2021 | 08:48 PM
  #267
Walleye Hunter
AD's provide a little more fuel but I'd want whichever were in the best condition.
Old Aug 4, 2021 | 08:58 PM
  #268
ok thank you ill see whats in the box.
Old Aug 4, 2021 | 08:59 PM
  #269
Ezalycasaid
So at this point with 70 psi post filter fuel pressure and everything my gauges are showing.... its an HPOP or injector issue right? The only thing not up to spec is the HPOP pressure only getting to 2650.
Old Aug 4, 2021 | 09:18 PM
  #270
ESwift's Avatar
ESwift
CNCFAB
E99 is a pwm converter just like l99
