Horn Wire
Old Jun 11, 2021 | 11:34 AM
Glxy66's Avatar
Glxy66
Horn Wire
Will someone please tell/show me the wire routing for the horn jumper wire when connecting the passenger side horn to the drivers side horn on a 56 F100. Also, are there clips involved and if so how many? Thanks for the info!
Old Jun 11, 2021 | 01:43 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
The second horn wire (Deluxe or Custom Cab) passes through the left wind deflector, then is bundled with the headlight/parking light wires. It is clipped (again with the same wires) under the latch panel, then passes back through the right wind deflector through a matching hole.
These clips:
Are mounted through these holes:
Ignore the screws in mine, my wiring is all aftermarket.
Edited to add: Here are the holes in the wind deflectors:
Driver's Side
Passenger's Side
Old Jun 14, 2021 | 07:42 AM
Glxy66's Avatar
Glxy66
Thank you very much for the great pictures, helps a lot. Wire is pretty long!
Old Jun 22, 2022 | 08:16 AM
nixoid's Avatar
nixoid
Steering Column
Hi guys.
I have a 53 F100 and assume this question applies to all 53-56 F100s. The wire that runs through the steering column, mine dropped down into the column. I was planned to replace it anyway so I sourced a new one. Inspecting the column, I do not see where the wire exits so that I can snake a wire up to replace the old one. Any suggestions?
Old Jun 22, 2022 | 01:14 PM
FortyNiner's Avatar
FortyNiner
Scrape the accumulated crud off the bottom of the column. Be aware that the crud may be filling the opening. It's there.
Old Jun 22, 2022 | 01:56 PM
EffieTrucker
Follow the pencil:
Old Jun 22, 2022 | 03:34 PM
nixoid's Avatar
nixoid
Originally Posted by EffieTrucker
Follow the pencil:
Thanks for the quick response and the visual aid. I didn't see a wire 5here but will check again.
Old Jun 22, 2022 | 05:12 PM
artscott61's Avatar
artscott61
Veteran: Navy
Where is the proper location for the horns? Mine are located on the inner fender panel to the front. The pictures look like they go on the wind deflectors.
Old Jun 22, 2022 | 08:33 PM
EffieTrucker
The horns are bolted into threaded holes in the radiator support. Mine are after-market and only have one bolt. The original horns have two bolts.
Old Jun 25, 2022 | 09:00 AM
nixoid's Avatar
nixoid
I've had some progress, found the hole and ran the wire, found the connection on the loom to connect the horn. Now I'm trying to figure out the "order" of the components. In particular, the horn spring (#7 on my image). Does the center of the spring rise to meet the rider or does the center of the horn spring point to the firewall?
Kev
Old Aug 8, 2022 | 02:36 PM
TX Chris's Avatar
TX Chris
delete. wrong thread.
n4gnr
35
Mar 31, 2021 06:39 AM
FordRun
18
Sep 19, 2012 08:33 PM
oneofakind97
Nov 9, 2007 07:12 PM
