Fuel Rail Removal Help
Old Jun 11, 2021 | 09:13 AM
JGRNAUT_7.3L's Avatar
JGRNAUT_7.3L
Anyone have a write up or instructions how to remove the rh fuel rail? I need to remove the valve cover (after loosing coper injector washer) and found instructions for that, but it just says remove the fuel rail, see section ** for instructions but I don't have that section as it was just a pdf out of a manual. As well anyone know if there is anything special I have to do after taking it off to purge the rail of air? Just turning the key on and off like the fuel filter?
This was suppose to be a easy quick replacement of injector #1 and now has turned in major headache. Luckily was able to source all the parts from 4 different places to be able to remove and replace the cover.
Old Jun 13, 2021 | 06:40 AM
senix's Avatar
senix
after repairs, yes key on and off as normal for the air purge.
You also have to program the new injector into the pcm.
As for the fuel rails, use you tube and search, there should be a video out there to assist with any special tools and how too.
A lot of this stuff is one time use so watch the video first and order the parts.
97vanswap
Nov 9, 2017 08:16 PM
dchamberlain
Oct 2, 2010 09:55 PM
vze2sgxa
Nov 13, 2007 02:23 PM
vze2sgxa
1997 - 2003 F150
Oct 24, 2007 08:34 PM
fordman954
Bronco II
Mar 26, 2006 12:32 AM
