How do you remove the fuel rail off the 2.9 bronco motor? All The injectors on different angles and it seems impossible to remove. All the hardware has been removed and it still wont come all of the way off...Whats the trick to removing the fuel rail?
once you remove the 3 or 4 screws holding the fuel rail,you have to pull the fuel rail and injectors out together,i pulled mine straight up..i really had to tug on it,but they did come out,just make sure you replace all the seals when putting back together.hope this helps!
