Sponsored by: Real Truck
Tire Wear Problems
Old Jun 9, 2021 | 10:06 AM
PJWhelan's Avatar
PJWhelan
Tire Wear Problems
When a front tire wears out (on the inside thread), what is the cause specifically. I rotated the tires in the correct pattern but noticed a similar pattern emerge on the newly rotated tire. Truck doesn't pull either way but I want to get an idea as why the "feathering" appears. Ball Joints? Camber in or out, I'm not sure.
Thank you!
Old Jun 9, 2021 | 11:42 PM
2001F350dualwheel's Avatar
2001F350dualwheel
Thank you!
When the wear occurs only on the inner edge of the tire, it’s usually negative camber and possibly also toe settings. It is also possible that there may be issues in your car’s springs, bushings, BJs. Do you have a heavy winch style bumper? Ladder rack loaded on one side?
start checking ball joints first.
Old Jun 10, 2021 | 11:12 AM
PJWhelan's Avatar
PJWhelan
So, no heavy duty winch bumper and no ladder racks. I know these ball joints are at least 8-9 years old if not more. I guess I could have it aligned as that hasn't been done in years. It would give me a starting point if they had seen something out of whack.
Old Jun 10, 2021 | 12:48 PM
99powerstrokedF250's Avatar
99powerstrokedF250
A good alignment shop will inspect all suspension components prior to doing an alignment, and if anything isn't up to snuff they'll refuse to do the alignment.
An okay shop will do the alignment anyway and give you a list of things that need to be addressed.
A shady shop will do the alignment without inspecting anything.
Old Jun 10, 2021 | 01:22 PM
2001F350dualwheel
Have a shop look at it. Most likely then all joints are worn and the camber/caster busing has gone bad. It’s located at the top ball joint and it’s like a sleeve with a hex crown. It comes in various degrees for settting up caster.
good to doo
Jan 20, 2017 11:43 AM
69ford99
2004 - 2008 F150
Jan 8, 2012 03:46 PM
fordsuperduty250
Oct 11, 2011 04:24 PM
No2Oil
Sep 13, 2005 08:16 PM
luxury 4x4
1978 - 1996 Big Bronco
Mar 3, 2002 06:37 PM
