Aerostar Ford Aerostar
fuel pressure drops quickly.
Old Jun 8, 2021 | 07:08 PM
zenish's Avatar
zenish
my van has been running really rough lately.very hard to start.i finally got a fuel guage and checked the pressure.everytime i turn the key to on i hear the pump run about three seconds.the first time the guage doesn't move at all.after five times the pressure is up to fifteen but drops immediatly.the pump runs three seconds each time.i raised it to look for leaks but i don't see any.1991 4.0.
Old Jun 9, 2021 | 02:37 AM
xlt4wd90's Avatar
xlt4wd90
Sounds like the fuel pressure regulator is not working properly. Pull its vacuum hose to see if there's gas in it. If so, its diaphragm has ruptured, and all that fuel that's supposed to be pressurizing is going into the intake manifold. Otherwise, it's bypassing too much fuel back into the tank.
Old Jun 9, 2021 | 11:36 AM
zenish's Avatar
zenish
i put a vaccum on the regulator and it held at 21 psi.it also turns out the vaccum line hooked to it was the one that i found unhooked on the other end but i left unhooked because i couldn't tell where it was supposed to go.so i hooked the guage directly to the output of the fuel filter.it did exactly the same.i assume the fuel pump has a check valve in it so since it bleeds right down the problems in or above the tank.
Old Jun 13, 2021 | 05:40 AM
zenish's Avatar
zenish
the hose between pump motor and the gas tank plate had split.it runs good now.great for a five cylinder imo.
Old Jun 13, 2021 | 07:48 PM
zenish's Avatar
zenish
and then all[much] the transmission fluid poured out on the crossover pipe again.
Old Jun 16, 2021 | 03:24 PM
zenish's Avatar
zenish
seven quarts later back on the road.
Old Jun 20, 2021 | 01:04 PM
sittinguy's Avatar
sittinguy
Tranny dumping when hot, had the same thing couple years ago. Had to bite the bullet and have it pulled at the shop and fully resealed, went ahead and let them replace the torque converter while it was out. It wasn't cheap, I guess the front seal could just be changed, but I wanted the full seal job
cjben
Aug 30, 2015 11:24 PM
djed
Jan 7, 2013 05:55 AM
bronco cam
1978 - 1996 Big Bronco
29
Jun 13, 2011 02:59 AM
Rodman64
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 15, 2006 09:39 PM
cleanstreak
Apr 3, 2003 07:23 AM
