Vin decoding help
Old Jun 8, 2021 | 03:48 PM
Rookie300's Avatar
Rookie300
Vin decoding help
Hi guys. I just purchased what I believe to be a ‘72 f-350 dually. I have tried to check the vin and I’m coming up on dead ends. I think the truck is a cab and chassis. It is a big block 429 or 460 with a two barrel carb. The vin is f37yrno3845 can any one help me with this decoding? Thank you in advance!
Old Jun 9, 2021 | 01:12 PM
4drocket's Avatar
4drocket
@NumberDummy
f37 prolly can n chassis? as f350 is f35
y is a 360
r is made in san jose ca
N03845 i cannot find
i added the big dummy to this so hopefully he will clarify as he is really a genius when it comes to anything ford
Old Jun 9, 2021 | 01:32 PM
lah2420's Avatar
lah2420
The N03845 is the consecutive serial number. Probably made in November 1971
Old Jun 9, 2021 | 02:15 PM
4drocket's Avatar
4drocket
@lah2420
i dont have a horse in this race but out of curiosity do you know what the f37 is?
Old Jun 9, 2021 | 03:09 PM
Rookie300's Avatar
Rookie300
Thanks for the help. I found another book I. The truck that talks about unfinished cab and chassis. Yet it has a different vin on it. The f37 is the confusing part. I found f350 badges in the truck so I assumed if was a 350. Yet we know how that goes….
Old Jun 9, 2021 | 03:16 PM
RichS2659's Avatar
RichS2659
It is an F-350. The F37 is Fordspeak for an F-350 2wd cab and chassis model.
Old Jun 9, 2021 | 03:33 PM
Rookie300's Avatar
Rookie300
Cool! Thanks guys. Now I am off to find out what the engine is that is in it. It looks to big to be a 390. Yet I’ll have a better idea after it gets a bath. Thanks again gents
Old Jun 9, 2021 | 04:24 PM
49F1Ken's Avatar
49F1Ken
Here is a link to a good vin decoder, that has all of that info on it.
Decoding Your 1972 Ford Truck VIN - FORDification.com
Old Jun 9, 2021 | 04:52 PM
4drocket's Avatar
4drocket
according to the vin its got a 360 in it and you cant tell the difference between that and a 390 without measuring the stroke
Old Jun 9, 2021 | 07:04 PM
Rookie300's Avatar
Rookie300
Thanks 4drocket!
I did some research and scrubbing and found the block # it is D1VE with 6015A below that. Looks like that is a ‘71 429 or 460. The head casting # is D0VE-C. From what I can tell the head are 75cc chambers from 1970.
Any body know what the 6015A stands for?
Old Jun 9, 2021 | 07:56 PM
4drocket's Avatar
4drocket
if it dont have the engine it came with from the factory then its probably a pick n pull special with who knows what from who knows where. good luck with that project. from what i read its most likely a 460.
Old Jun 9, 2021 | 08:05 PM
85e150's Avatar
85e150
6015 is the basic part number for a block, all blocks all years. (most anyway, not sure of the cutoff)
A would be a revision or version of the block.
Old Jun 9, 2021 | 09:19 PM
Rookie300's Avatar
Rookie300
Thank you gents for all the helpful information!!
fslay
Large Truck
May 24, 2021 03:58 AM
Jdhacker
Large Truck
Jun 5, 2013 01:19 PM
rocfire
Apr 26, 2013 02:48 PM
