7.3 Godzilla catastrophic failure
Not sure that has anything to do with Covid supply issues. Would like to see Ford go to the AAM 11.5 though.........
My month old 2022 RV with a 2021 ford chassis and Godzilla engine failed as well at 6800miles.
For those of you with this engine in your RV or truck here is how you will know yours has this known defect;
You will start throwing a CEL for multiple cylinder misfires and ford will misdiagnose it and send you on your way until it eventually throws a rod through the block.
Here is how mine went down:
Just by chance I put my code reader on it because of a gas cap loose alert on dash. Gas cap wasn't loose so just wanted to see if I could reset the code and the prompt would go away. When I pulled the codes it had the gas cap code but also and another older "multiple cylinder misfire". The check engine light wasn't on so I thought maybe it was bad gas that caused it. That was at around 5000 miles when I checked it. On my vacation 1500 miles later (July 12th 2021)we were coming out of the hills from Mount Rushmore and it started throwing a CEL light. I was 5 miles outside Gillette Wyoming so I drove straight into the ford dealer there. They don't have lifts for this size of vehicle so they sent me to their medium duty truck center, interstate power systems to change the plug wires because they were known to get bad batches on this new engine causing the same issue which was "multiple cylinder misfire". It also created an audible tick so they changed the plugs as well which it went away after that. The mechanic said if it starts having issues again to request they change out the coil pack because Gillette ford didn't have any in stock. Since this caused us two days we just canceled our trip to Yellowstone and headed back to Texas going through Denver because the Rush truck center there should have all the parts we would ever need if we have any more issues. About 70 miles outside of Denver we started getting the check engine light again. Headed for the next exit going down a steep incline that's when we heard a sound like dragging chains and the engine cut off. When they towed it to the ford dealer the mechanics said it had a visible hole in the side of the engine.
After two weeks of Ford fighting with Rush truck centers who handles there contract for medium duty trucks they finally agreed to tow it there. Unknown to me when it got there it was in line with 8 other RV's that have the same issue,,, So over four months later I only have 3 more in front of me until mine gets worked on which should be around Jan 2022 according to the Ford rep. Purchased the RV new on June 3rd 2021, broke down on July 14th. I'll let everyone know what the mechanics say if I ever get it back..
Wford@ford.com
This is Bill Ford's email. Please be concise in your explanation to him. He will get someone on it. He did for me. If you complain it goes nowhere. Best of luck.
Sorry to hear of your troubles. While 7.3L failures in Super Duty pickups have been rare, it's starting to look like there are issues with this engine in motorhomes. I am interested to see if there have been problems in the 7.3L Super Duty 650 and 750 trucks yet, but there seems to be so few of them around it's hard to say. In any event, I hope your issue is resolved sooner than next year. I don't know what state you are from, but where I live this would be an easy 'lemon law' case if you wanted out of it. Sure, give Bill Ford a chance but I think you ought to be compensated for your trouble and unavailability of your RV in addition to just getting it fixed.
It doesn't make sense to me either. That's why I am wondering how the 7.3L is doing in the 650 and 750, I would think if the engine is having issues in motorhomes it would be having issues in the larger truck as well.
I wonder if this has anything to do with the stoichiometric combustion Ford highly touted when this engine cane out. From my understanding, stoichiometric equals a maximum safe lean condition. Lean, shouldn't equal thrown rods, but something weird is happening.
Thanks for the updates.
Unless..... the "lean code" is too far below the stoichiometric condition? Trying to squeeze every 1/8th MPG out of the thing. Who knows? I have no doubt it's a great engine, I'm just curious about this failure mode.
All I'm saying is I was told not to buy a 2021, or late 2020, or anything at least through early 2022. I was told by someone on the front line of OEM manufacturing, that with the parts shortages, OEMs are sourcing parts to build components wherever they can find them, and these sourced parts are many times below spec, yet approved to be used by the OEM.
I can not be any more specific than that to protect the source. I can say that if anyone would know, this person would.
