Head light problem
Old Oct 29, 2003 | 10:47 PM
BlueAngel69's Avatar
BlueAngel69
Question Headlight problem
Well hi to all !
My problem is, my lights.
I have a 69 F100 with P/S (customized) with the 3 on the tree.
Well, when i bought her she had been wrecked & the guy had put a 72 grille in place of the wrecked grille.
So you can see that this is itching for lighting problem right?
I parked it bout 3 to 4 years ago, thinking i was going to sell her (gave up looking for grille).
This year i started fixing her again and found that my headlights dont like to work and when they do, the driver side is really dim and my dash lights don't work.
The high to low switch doesn't work either.
any help PLEASE.
Old Oct 30, 2003 | 12:12 AM
NM5K's Avatar
NM5K
All the usual...Check all grounds, ground connections. From there you would want to make sure the proper wires are actually connected to where they should be. You might have to find a diagram. Sounds like some of the front lights in the new grille may not be connected properly, being the brights don't work. But the dimmer switch "could" be bad. Fairly unlikely though, if you can hear it click, and it feels normal, and not like it's fixing to fall apart. Offhand, I put my money on bad wiring, being the front end has been worked on. From there, you need to check for voltage drops, and proper voltage at the proper lights. IE: both elements when the brights are on, etc. As far as cab, same drill.. Check all grounds. make sure all bulbs are good, as I've heard reports of possible series wiring. One bad bulb would kill all in this case. Wiggle the dash light dimmer rheostat to see if the lights will come on at a different setting. You can get dead spots. You'll need a volt-ohmmeter to do any real testing. MK
Old Oct 30, 2003 | 12:14 AM
BB's Avatar
BB
Hi! Welcome to the site!
When you parked your truck, did this stuff all work or was it flackey too? I'd start by checking all your connections and grounds, especially around the "new" grille. The dimmer switch is probably bad too, they don't last forever on the floor. Dash lights could be a bad ground or the rheostat in the headlight switch is shot, try turning the **** back and forth. Well, that's a start. Looking forward to seeing some pics of Blue Angel, and thanks for the explanation.
Barry
Old Oct 30, 2003 | 12:17 AM
BB's Avatar
BB
Sheesh MK, you must have posted when I started typing.
Anyway, welcome again BlueAngel69!
Barry
Old Oct 30, 2003 | 12:18 AM
BlueAngel69
all stuff worked when parked light s dash and head lights then a year ago the dimmer swtch went funky
Old Oct 30, 2003 | 12:23 AM
BlueAngel69
i got pics but i cant figure on how to up load them
Old Oct 30, 2003 | 12:40 AM
BB's Avatar
BB
Ok, click on “Galleries” in the upper right, click “Manage” your gallery, click “Create Album”, fill out all the info and then hit the “Create Album” button at the bottom. Now you got a gallery. To upload pics, hit the “Browse…” button and find the pic on your pc, click on it and you should see it in the window. Hit the “Upload” button and there you go. Note the maximum image file size is 320000 bytes and 1024x768. Image types can be JPG/JPEG, GIF or PNG.
Barry
Old Oct 30, 2003 | 12:42 AM
BlueAngel69
ok ill give t a shot
Old Oct 30, 2003 | 11:39 AM
pward76's Avatar
pward76
If you parked it for 3 or 4 years ago, and depending on where you parked it (like outside) - it is a distinct possibility that mice have chewed some of your wiring. Start at the lights and work back, examining all exposed wires for chewed spots....
Just hope they didn't chew the ones under the dash -
Good luck and let us know how it comes out.
Old Oct 30, 2003 | 11:45 AM
BB's Avatar
BB
Oh yeah, varmints! I had mice chew up the wiring on my Capri, they seem to like rubber.
Barry
Old Oct 30, 2003 | 01:04 PM
BlueAngel69
mice i dont have probelm i hadit parked in the back by a tree
2horses
May 9, 2011 01:49 PM
Traxxis
Oklahoma Chapter
Jul 28, 2009 09:40 PM
PinkyRingz
2004 - 2008 F150
Feb 25, 2008 01:35 PM
jd_sylvia
Jan 29, 2006 10:29 AM
GA69Ranger
Apr 27, 2002 10:55 PM
