Dose a 1995 150 with a M5OD have a speed sensor in the transmission? Mine has been swapped with a older trans. There is an extra plug and my speedo/cruise control dosent work. I have replaced the rear end sensor and the ABS light went out.
I have 3 connectors on the transmission harness. One goes to the reverse light switch, and one to the 4WD switch. The 3rd is longer than the rest too.
Looking on rock auto and parts stores they show a second speed sensor with a gear on the end. It uses a small plate to hold it in. On the passenger side of the transmission there looks like a plug held in with the same plate. Is this for the speedo/cruise?
On my 250 it's all done with the rear sensor, which is why I replaced it first.
