View Poll Results: Can anyone help with my 95 f150
Bad slave
0%
Need to be bleed more
0%
Voters: 0. You may not vote on this poll
Clutch problems
Old Jun 3, 2021 | 04:17 PM
Roberts04's Avatar
Roberts04
Clutch problems
I replaced the clutch slave and mater I bench bleed the master but forgot to do the slave. I've went through a 32 oz bottle of fluid bleeding everything. Still cant get the clutch to release to be able to shift gears can anyone tell me what I'm doing wrong or point me in the right direction I'm at my witts end dont know what else to do. Plz and thanks
Old Jun 3, 2021 | 05:08 PM
88n94's Avatar
88n94
I have good luck gravity bleeding the clutch. Fill the clutch master cylinder with brake fluid and leave the cap and rubber cup off so as not to create a vacuum lock. Loosen the bleeder valve on the slave cylinder and let the fluid drain through adding fluid to the master cylinder as to never let it run dry. Let maybe a pint of fluid run through and top up the master cylinder. Works for me.
Old Jun 4, 2021 | 06:54 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Clutch dish installed backwards?
Roberts04
Jun 4, 2021 08:26 AM
fordka
Jan 14, 2015 12:46 AM
vektron75
Feb 23, 2012 06:37 PM
84-F150
Apr 15, 2008 01:00 PM
hoxiii
May 1, 2007 08:05 PM
