Cranks but no start!
Old Jun 2, 2021 | 12:47 PM
Stan P's Avatar
Stan P
Really stumped about this one. 2006 F150, 5.4, 157000. Stopped at light and it just died on me. The little info window said "check gauges" Tried starting for a couple of minutes and she finally started but was running rough for a few seconds then ran ok and i got it home. Tried starting again to read codes but she wouldn't start. Tried starting the next day and she started right up. Ran ok for a few days, maybe noticed a little rough idle and low rpm's around 520 when stopped in drive. No codes. Fuel pressure seemed okay around 39 psi.
Sooooooo, this is what i have done so far with no success: Replaced FPDM, replaced fuel pump, switched relays around, checked fuses, checked power at terminal of one coil and it was getting juice. Checked inertia switch. Still cranks with no start.
The only other thing I was able to find as a probable solution is the cam shaft sensors.
Any suggestions would be greatly appreciated.
Thanks!
Old Jun 3, 2021 | 08:29 AM
alloro's Avatar
alloro
The engine does not need to be running to check for codes. Turn the key to the on position and initiate the scan.
Old Jun 3, 2021 | 09:00 AM
Stan P's Avatar
Stan P
Sorry I didn't explain thoroughly. After she initially died, I was able to get her started and did run for codes and have some live data. There were no codes.
Thanks,
Stan
Old Jun 4, 2021 | 08:28 AM
redfishtd's Avatar
redfishtd
Pull vct connectors see if see runs better
Old Jun 7, 2021 | 10:49 AM
Stan P's Avatar
Stan P
Thanks for your response, but I was not able to start her back up since my original post. Next attempt is to replace crank position sensors.
Old Feb 21, 2022 | 11:29 PM
Ray6797's Avatar
Ray6797
I'm having same issue
I've changed all those and the starter and I plugs but my injectors are starting stand e of fuel so that's my next battle.
Joe Bowen
Modular V8 (4.6L, 5.4L)
Apr 9, 2021 06:00 PM
Yems427
Nov 2, 2020 01:33 PM
Sup3rtallpaul
2004 - 2008 F150
17
Jul 23, 2019 12:14 PM
j1586
Jun 13, 2011 01:35 AM
