Brake dust common?
Old May 31, 2021 | 01:53 PM
05F250DSL's Avatar
05F250DSL
Brake dust common?
So I’ve had my truck for literally 9 days it is used. My rims were dark grey in a matter of 400 miles. I am not hard on the brakes. Wondering if this is common or someone did a brake job with cheap pads? Or did the dealers massive amounts of tire shine just catch all the dust.
Old May 31, 2021 | 02:08 PM
nickshu's Avatar
nickshu
Yes the stock pads dust really badly. Especially the fronts. I have had my 2021 less than 3 months but planning on swapping out the pads to something that dusts less.
Old May 31, 2021 | 02:11 PM
Sailor#10's Avatar
Sailor#10
My 2017 has stock pads and the front wheels get covered with a tan colored dust.
Old May 31, 2021 | 03:37 PM
George C's Avatar
George C
Anyone have suggestions on pads?
Old May 31, 2021 | 04:17 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
I did a Powerstop kit (rotors and pads ) and the braking is better and much less dust !!!
Old May 31, 2021 | 04:34 PM
JHForman812's Avatar
JHForman812
This is an issue going back to at least 2019(my truck) the brake dust trashed my aftermarket wheels, It took tons of elbow grease to fix them!
Old May 31, 2021 | 04:46 PM
SuperDuty Wannabe's Avatar
SuperDuty Wannabe
I generally install new Pads at my first Oil Change because of the O.E.Pads making so much Dust. I've had good luck with EBC Green Stuff Pads.
Old May 31, 2021 | 05:42 PM
05F250DSL's Avatar
05F250DSL
That was my next question our other vehicles have come with ceramic pads and seem to dust less. Any insight or reasons they don’t do good on the super duty? I’ll have to look up the green pads mentioned I never heard of them.
Old May 31, 2021 | 06:27 PM
Je942010's Avatar
Je942010
I just changed the pads on my 2020 and I only have 1,900 miles. I left the factory rotors and installed Powerstop extreme truck and tow carbon ceramic pads front and rear. Since I installed them I can say the dust has been cut down 90-95%. I have aftermarket wheels on my dually and didn’t want to deal with having to clean them constantly.
Old May 31, 2021 | 06:51 PM
tjcj's Avatar
tjcj
F250 and up come with Semi Metallic pads OE. In a nutshell metallic pads are more aggressive and less prone to fade. Ceramics are cleaner but can fade under heavy use, trailer towing, mountains. After initial break in your oe metallics should dust less. Akebono does offer a ceramic pad for the new Fords. I work(ed) for OE and Aftermarket manufacturer, Aftermarket Wholesale, Management, and Retail. Close to retirement. Our main supplier offers several grades of semi metallic, no ceramic yet. I run top tier ceramics on my 01 with no problems but I am a flatlander with occasional trailer towing. Be aware that there are many many formulations of pad material within each category. People ask me: how much are your brake pads? my usual response is: how fast do you want to stop?
Old May 31, 2021 | 10:28 PM
Absoluteblack2018's Avatar
Absoluteblack2018
Just finally swapped out the OEM brakes on my 2018, at 89k miles. They've been producing so much dust since I've owned the truck (typically within 3-5 days of washing my truck the wheels are coated). Now on powerstop extreme ceramic pads and rotors after nearly 3 weeks almost zero dust. I'm 100% sold on them just for dust, but braking is also much better.
greenterror
Mar 4, 2007 09:09 AM
iziris
1997 - 2003 F150
Feb 8, 2007 09:52 PM
Beefford
2004 - 2008 F150
Jun 9, 2005 04:28 PM
dampam6535
2004 - 2008 F150
Sep 23, 2004 08:25 PM
41Clay
Jul 9, 2003 08:17 PM
