Thermostat Replacement 352 FE
Old May 31, 2021 | 12:24 PM
mulegal's Avatar
mulegal
Thermostat has failed on the 65. It's a big substantial 63mm made in USA. Numbers 160 and 7302 are stamped on one side. Stuck closed even in boiling water.
Any recommends on a replacement stat? quality ones available??
Stock 352, no ac, ...HOT summer environ around here
Old May 31, 2021 | 12:56 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
These, ATND (According To NumberDummy) are your choices, I believe, at least for the 1966 models. I got mine cheap and NOS off the Bay, and there are both available there right now. The RT-16 (160 degree) one I saw is listed @ 4.99.
@NumberDummy
@NumberDummy
[img]images/statusicon/user_offline.gif[/img]
Ford Parts Specialist
Quote:
Originally Posted by rebel33382 [img]images/buttons/viewpost.gif[/img]
The style dennis carpenter list is like the one I pulled out. What is the difference between that style and the traditional stant at any auto parts store?
http://www.parts123.com/parts123/yb....Z5Z5Z50000024G
Aftermarket "gypo" autoparts store replacement. It doesn't look like the originals and DC's part number & applications are wrong. [img]images/smilies/frown.gif[/img]
2 1/2" diameter t/stat used on Passenger Cars thru mid-year 1966, on F100/350's thru 1967. These same 2 1/2" t/stats date back to 1949, were used in many other vehicles/engine sizes.
2 1/8" diameter t/stats introduced mid-year 1966 (cars), 1968 (trucks).
NAPA has the correct 2 1/2" t/stats, but they aren't listed on their computers. You have to get the partsclucks to actually look in their paper parts catalogs, usually stashed under the counter.
Genuine Ford Parts:
A8AZ-8575-D .. 160 degree Thermostat / 2 1/2" Flange Diameter (Motorcraft RT-16) / Obsolete ~ 80 available NOS
A8AZ-8575-E .. 180 degree Thermostat / 2 1/2" Flange Diameter (Motorcraft RT-18) / Obsolete ~ 73 available NOS
If anyone's interested, I'll list some of the sources that have these two puppies.
Old Jun 1, 2021 | 10:24 PM
mulegal's Avatar
mulegal
Thanks ibuzzard, Helps to have numbers.
Old Jun 2, 2021 | 09:17 AM
ibuzzard's Avatar
ibuzzard
I bought two t-stats, the one I needed plus a spare. I also bought an NORS t-stat housing I found, in case mine should ever crack or rust through, but I expect it will now outlive me. Anyway, my grandsons will inherit my truck in 15 years, along with a sizable amount of NOS and used parts to keep the truck going for a long time.
Old Jun 2, 2021 | 11:06 AM
mulegal's Avatar
mulegal
a reserve of spare parts is a comfort
Old Jun 2, 2021 | 04:05 PM
daveengelson's Avatar
daveengelson
In my opinion, DC has one of the worse item description websites, suggest make sure the thermostat does not use an 'O' ring to seal the thermo to the block as opposed to the gasket.
SeaCarr
Jan 22, 2021 11:26 AM
BulldogF250
Dec 27, 2019 10:37 AM
alchemist1
19
Mar 7, 2015 09:27 PM
Unimog005
Jul 31, 2005 01:01 PM
chris_2
Nov 13, 1999 05:11 PM
