A/C delay
Old May 30, 2021 | 04:24 PM
2002Limited's Avatar
2002Limited
A/C delay
Just noticed this issue today on my '02 Limited. Down here (Miami) it is ungodly hot, and my excursion sits outside on a brick driveway. First minute or two the A/C runs it is ambient, then it 'kicks in'. Once it is going, it's ice cold.
Old May 31, 2021 | 11:02 AM
projectSHO89's Avatar
projectSHO89
Check your clutch gap first. If that's not it, it gets more difficult.
Old May 31, 2021 | 01:08 PM
2002Limited
I'm right at .025" Clutch engages and disengages cleanly with the flip of the switch, so I'm just going to chalk this up to a couple really really hot days. Also it's hella pita to reach on the V-10. I haven't driven it in 4-5 months, so it isn't like something I noticed after driving it everyday. Had to swap out a battery because it sat so long, but 3 years is all you get down here in any case. I only notice it when I start it in a parking lot let's say, and it doesn't seem to be cooling but when I hit the road and the rpms come up it 'kicks in'. Or maybe it just needs a few minutes to cool down the hot ductwork before it can 'feel' cold out the vents.
Old May 31, 2021 | 04:20 PM
projectSHO89
Or maybe it just needs a few minutes to cool down the hot duct-work before it can 'feel' cold out the vents.
That's the way my 01 F250 behaves. I can tell the compressor is running but it has some work to do before it really makes a hugely noticeable difference in the vent outlet temps.
Old Jun 4, 2021 | 12:21 PM
bwguardian's Avatar
bwguardian
Are you opening the rear cargo windows to help get the hot air out. The A/C air supply from the front will push the hot air out the back. This really helps our Excursion during these hot humid summer days in Houston.
Old Jun 4, 2021 | 06:29 PM
01__Excursion's Avatar
01__Excursion
Sounds like the small delay is normal, it takes a min for the compressor to pump the refrigerant vapor to the condenser where it condenses to a liquid, and is then able to meter as a liquid through the strainer/orifice then boiling off to a vapor absorbing the heat passing through the evap coil.
Good reference here.
https://www.swepusa.com/refrigerant-...orators/asas8/
Money-Pit
Nov 4, 2013 05:27 PM
Hdslider
6.7L Power Stroke Diesel
16
Dec 11, 2011 05:34 PM
