Turn signals not working
Old May 30, 2021 | 04:06 PM
I-6 Addict's Avatar
I-6 Addict
Hey fellow Ford fans
two days ago the turn signals in my 87 F250 quit working. They don’t blink in the front or in the back or in the dash. However, my 4 flashers still work and I believe my brake lights are still working. I pulled and inspected all the fuses and they appear to be fine. So I’m assuming something else is wrong. Any ideas?
Old May 30, 2021 | 04:34 PM
obsxl's Avatar
obsxl
check the blinker relay. you can swap it out with the flasher relay to see if it’s the problem
Old May 30, 2021 | 04:50 PM
I-6 Addict's Avatar
I-6 Addict
Can you tell which one the blinker relay is? Is it in the fuse panel or somewhere else? Same with the flasher relay
Old May 30, 2021 | 05:20 PM
I-6 Addict's Avatar
I-6 Addict
Old May 30, 2021 | 05:51 PM
obsxl's Avatar
obsxl
it should be the big round relay in the fuse panel in the cab. the flasher relay is behind the blinker relay
Old May 30, 2021 | 06:36 PM
yardbird's Avatar
yardbird
Good luck getting the 4 way flasher out without loosing some blood on that '87. Recently changed mine out. I healed up after a few weeks...lol
Old May 31, 2021 | 07:29 PM
I-6 Addict's Avatar
I-6 Addict
Replaced the round relay and everything seems to work great. Thanks for all the help!
Old May 31, 2021 | 10:37 PM
yardbird's Avatar
yardbird
Good deal on the flasher being the problem. Good thing it's right there looking at you, and not where the 4 way is. The worst part is laying on your back doing floor exercises getting to the fuse panel.
wyrm73
Oct 26, 2015 11:27 PM
ford4604bbl
Mar 21, 2010 01:36 PM
KeysJK
Electrical Systems/Wiring
Jul 6, 2009 07:51 PM
574MF4
1997 - 2003 F150
Dec 7, 2005 05:50 PM
