I haven't posted anything as I've been lucky enough to have no problems with my 2001 F150 Supercrew that I couldn't figure out, until today. My signals stopped working, 4 way flashers work fine, the bulbs are all good so I think the flasher needs replacing. I've crawled everywhere under the dash looking for something that resembles a flasher. Can anyone give me a clue as to where it is. Thanks in advance.
HAve someone check and make sure your rear brake lights are working. If they're not, you may need to replace the turn signal assembly. GM's used to be common for this, which is why I always loved ford's amber turn signals- the brake lights didn't go through the turn signal switch! And now they have gone the other way...
