steering column
Old May 30, 2021 | 09:29 AM
lomesome1's Avatar
lomesome1
steering column
Another question, I am going to be putting a aftermarket steering column in my 56. When I took the stock one out it was a solid shaft down to the gear, my question is how do I brace the bottom of the column? Thanks
Old May 30, 2021 | 09:52 AM
52 Merc's Avatar
52 Merc
There are several ways to do it. here's some ideas, depending on how fancy you want to get. You can google steering column lower mount and find lots more ideas.
https://www.summitracing.com/parts/i...iABEgJKk_D_BwE
https://www.cjponyparts.com/borgeson...SABEgKsRvD_BwE
Old May 30, 2021 | 10:19 AM
fatfenders's Avatar
fatfenders
These are reasonably easy to fab with an exhaust clamp and a couple small pieces of angle bracket. That made a lot more sense 20 years ago and I ended up using the fancy swivel bracket 52Merc posted. The price is way down from when they first came out and you don't have to worry about concealing it.
Old May 30, 2021 | 10:59 AM
moejr's Avatar
moejr
I made one from a shaft collar, tack welded a couple flat washers to secure the column.
Old May 30, 2021 | 01:25 PM
1956_F100's Avatar
1956_F100
A question that comes to mind is how is the new column shaft attached to the original steering box? Since the cab is mounted on soft rubber pads and moves a fair amount relative to the frame, how is that relative movement accounted for with the new aftermarket column? When the original column is correctly mounted to the dash bracket, it is not clamped extremely tight so is allowed to move as needed.
Old May 30, 2021 | 10:12 PM
Chrytech's Avatar
Chrytech
column
Shortened a GM tilt column and welded mounting plate on it.
Use an intermediate slip shaft from column to box.
WTFORD
May 15, 2021 01:11 PM
Darrellt
May 22, 2017 12:57 PM
66f-100
Apr 9, 2011 05:58 PM
Bigdaddy29384
Feb 11, 2005 05:11 AM
