Solid door glass 1953-1955
Old May 29, 2021 | 07:02 PM
Nick Martorano's Avatar
Nick Martorano
Happy Memorial Day Weekend! I want to install solid door glass (one piece windows) in my 54 F100. I am sure a bunch of you have done! Can you share which companies windows a kit you used? I appreciate your help guys.
Old May 29, 2021 | 07:07 PM
Marten's Avatar
Marten
Bought my glass, window kit, power windows stuff from Midfifty. Switches I got from Summit.
Old May 29, 2021 | 07:51 PM
Nick Martorano
Thank you Marten. Did you do curved glass or straight?
Old May 30, 2021 | 04:57 AM
Marten's Avatar
Marten
I used the curved glass. The straight glass involves cutting up your doors both inside and out to make work.
Old May 31, 2021 | 05:00 AM
Nick Martorano
Thanks again Marten. Any issues with the install? Was it straight forward?
Old May 31, 2021 | 05:58 AM
1954F100ranger's Avatar
1954F100ranger
Here is a link to the tinted glass at mid fifty.
Tinted curved glass
I wonder if it is tinted green, kind of like the old green coke bottles. Anything real dark wouldn't work for me. Night cruising is a problem for me if the glass is too dark.
Old May 31, 2021 | 07:30 AM
big job's Avatar
big job
I can not live without my vent windows in any vehicle !!!!!
Old May 31, 2021 | 08:25 AM
CharlieLed's Avatar
CharlieLed
I have done both the curved and the flat 1-piece side window installs using the MidFifty kits. The first question I would ask is, "who is doing the install"? If you are doing it yourself then you should be able to weld sheetmetal...more so with the flat glass but still some welding on the inner door with both applications. When the side window goes from stock to 1-piece the glass extends into the hinge pocket inside the door, this pocket needs to be cut so that the front window guide can be fixed in place. Access panels are cut out of the inner door to facilitate this mod and must be welded back in place. The flat glass install entails making the window slot in the top of the door straight by welding in new pieces that hold the felt wipers. It is not readily noticeable on an assembled door but the vent wing is on an angle from the side window...curved glass compensates for this bend whereas the flat glass kit eliminates the bend. The flat glass install entails more welding but in my opinion it is a much cleaner look...more like the 56 side windows.
Old May 31, 2021 | 07:55 PM
Marten's Avatar
Marten
I had never done it before, actually never built a hot rod before. That is random crap knowledge that will come into play. I had a hard time reading the instructions and translating it to the doing part. But slow and steady and I got it. The second side was much easier. I did the drivers side first and it works perfect, although I will probably lubricate the channels a bit as the window is a bit hard to go up. The passenger side I am having some trouble with now. Not sure why yet but it keeps jumping out f the track about 1/2 way up, I go down an inch and then up and it is fine. I will figure it out. I like the look of the one piece and that is why I went with it. You do have to do some cutting of the inside of the door but not a big deal, depending on what your finish door will look like, You do put the parts you cut out back in, the instructions say to screw them in. I will do that and cover the door with some sort of panel until I paint the truck and buy the interior finishes. For glass I went with clear, the green is like an old coke bottle colour and I did not want that look. If I need it tinted I will have that done locally.
Old May 31, 2021 | 08:03 PM
56panelford's Avatar
56panelford
Tinted curved glass
Midfifty sells it in smoke also, that's wear I bought mine for both my 56's
Old Jun 2, 2021 | 02:40 PM
Nick Martorano
Thank you John,
I will check them out.
Old Jan 9, 2024 | 07:48 AM
53fatfndrf100's Avatar
53fatfndrf100
1st Gear
Sorry to bring up a old thread but to those that have done this swap, I have recently purchased a 1954 f100 that the previous owner was in the process of installing a solid curved window kit from midfifty. I reached out to midfifty but no luck with them going out of business I guess. Does anyone have what parts should have came with this kit? I have two angled rails, glass, a few bolts/screws and the felt strips that go in the bottom of window opening.
Do you reuse the factory slide on the door striker side?
Old Jan 9, 2024 | 08:23 AM
CharlieLed's Avatar
CharlieLed
Sounds like you've got the whole kit. Rear channel is reused and the front channel is in the kit.
Here is the instruction file: INST-CURVED_SOLID_SIDE-R.pdf (midfifty.com)
whisler
Aug 13, 2019 07:09 PM
mixup
Jul 10, 2014 07:05 PM
don1077
Jun 29, 2008 07:24 AM
53f100owner
Mar 3, 2008 08:21 PM
