1995 Fuel Help
Old May 26, 2021 | 02:43 PM
Wustruck's Avatar
Wustruck
Trailering
1995 Fuel Help
Hey all,
I've got a 95' 5.0 with around 140,000 miles. It was running just fine in the morning and then wouldn't start in the evening. I'm confident my issue is fuel as there is literally zero pressure at the rail. I get a KOEO code 542 (fuel pump secondary circuit failure). The engine will crank but fails to start.
Things I have tried to no success:
  • replaced fuel filter
  • checked inertia shutoff
  • replaced all fuses and relays relating to fuel system
  • tried starting from both tanks
  • turning key results in no sound from either tank
  • sprayed ether into intake and engine would fire (RIP arm hair)
  • disconnected fuel line behind the fuel filter and turned key---bone dry
So my question is- if I have two fuel pumps (one for each tank), I doubt both would go bad at the same time although would that mean they are on the same circuit? If so can someone point me to the name and location of the grounds? Reading through some other posts is it possible a faulty PCM is at fault? Any other ideas?
Much appreciated!
Old May 26, 2021 | 05:24 PM
Ckierstead22's Avatar
Ckierstead22
Murphy's law says they can. If you get no sound from either pump when you turn the key, then I would suggest checking electrical connections at the pump or the pumps are shot. Either way you have to drop the tanks or pull the bed off.
DoctorSharpY
22
Jan 20, 2019 11:38 PM
coloradojeep1
Nov 23, 2017 06:57 PM
spivf350
Mar 21, 2014 12:53 PM
Redneckfordf2502002
16
Jan 8, 2014 05:04 PM
Cinda56
Mar 24, 2008 06:43 AM
