Hi/Low Beam Confusion
Old May 25, 2021 | 03:24 PM
Capt'n Jack's Avatar
Capt'n Jack
I have the factory driving lights in the bumper that turn on by pulling the light switch. They come on with the headlights off, and only with the low beams. Everything works as it should. I recently changed to LED bulbs in the factory headlight assembly. Now, the driving lights still function as they should, but when I switch from high to low beam, the high beams stay on. With the lights on, If I push the driving light switch in, the highs go off and the low beams come on as they should. With the lights off, the driving lights come on as they should. I'm guessing it's an amperage issue. Anybody come across this before?
Old May 25, 2021 | 03:39 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I can't say what your high to low beam problem is but you DO NOT have "driving lights". By definition of the way they function (low beam operation ONLY, beam pattern, and selectable operation) they are fog lights. They're annoying to everyone else when it's not foggy and are illegal to use by themselves (without headlights on) in most every state.
"Driving lights" are to be used with high beams only.
Since I've ranted and my point/PSA has been ignored and pissed off everyone here, I hope you find a solution to your problem.
Old May 25, 2021 | 03:51 PM
Capt'n Jack
I have spent the last 20 years working in a max security prison, I don't offend easily.
Let me re-post my problem:
I have the factory fog lights in the bumper that turn on by pulling the light switch. They come on with the headlights off, and only with the low beams. Everything works as it should. I recently changed to LED bulbs in the factory headlight assembly. Now, the fog lights still function as they should, but when I switch from high to low beam, the high beams stay on, essentially turning my fog lights into driving lights. With the lights on, If I push the fog light switch in, the highs go off and the low beams come on as they should. With the lights off, the fog lights come on as they should. I'm guessing it's an amperage issue. Anybody come across this before?
If it wasn't for the high beam indicator light in the dash, I would just switch the high and low beam wires at the bulb and leave it working like it is. Except replace the fog lights with a 21" LED bar so I can see more of the road in front of me.
rick_johnson
Mar 27, 2021 12:32 AM
scarface78
Nov 12, 2005 09:12 AM
MattamiscontisME
Apr 1, 2005 04:31 AM
wagon burner
1997 - 2003 F150
15
Oct 21, 2004 09:18 AM
Debby
Feb 14, 2002 01:44 AM
