Tires balanced, replaced two rear tires
Driveshaft balanced with new ujoints and carrier bearing
front leaf spring bushings were replaced about 20,000 miles ago and I just recently put new rear leafs in with new bushings.
Still same vibration around 42 mph...........can also feel it at higher speeds.......Also seems like you can hear a drone
Anything else to check/look for?
If you have a manual transmission, you could have a Dual Mass Flywheel and if the springs are shot it will cause a very difficult to track down vibration. Took us months to figure it out
