E4OD limp mode/2nd shift issue FIXED
Old May 25, 2021 | 01:27 PM
Mickw's Avatar
Mickw
Recently bought a 1995 f150, 351W, E4OD tranny. Guy who i bought it from said it would need some transmission work, specifically a shift solenoid.
here were the symptoms
Bogging down when shifting into 2nd/limp mode
truck would shift from manual 1st, to manual 2nd, then drive fine, the check engine light NEVER came on. Even trying to **** it off by disconnecting stuff.
battery voltage was low, had a rough start. With low voltage that boosted once the alt kicked in.
i wanted to check out the electronics first, hookup to the solenoid, MLPS, VSS, even the battery, lastly, knew it mightve been a far stretch, but i removed the PCM to find rust, alot of it. Cracked open the case, blown out circuits, sand, melted stuff.
Tested the battery, at about 50% capacity, and the battery was too big by about 100 CCA. Swapped it with the correct battery size, put a new pre programmed PCM from cardone in, she was good to go. Smooth shifts, strong start!
Old May 25, 2021 | 03:00 PM
torq'ta 5 8's Avatar
torq'ta 5 8
Welcome to FTE
Thanks for sharing, got pics of truck.
Old May 25, 2021 | 03:23 PM
sandymane's Avatar
sandymane
If you want to find the source of the water/rust issue, you can open the hood and hose water on the cowling and window seals. The cowling is an issue discussed here often and info is available to fix it.
Old May 25, 2021 | 06:05 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Mickw
….and the battery was too big by about 100 CCA. Swapped it with the correct battery size,…
A battery with more CCA is not a problem but one too small is.
Glad to hear you got it fixed.
1949Red
Apr 29, 2021 07:47 AM
union_guy
May 25, 2020 10:51 AM
firstrider
Apr 18, 2018 03:04 AM
flhx06
18
Sep 19, 2017 12:32 PM
Longbed92
Ford Truck Parts for Sale
Dec 6, 2012 09:05 PM
