Sponsored by: Real Truck
2006 6.0 STRANDED!
Old May 25, 2021 | 01:25 PM
MoneyPit6O's Avatar
MoneyPit6O
2006 6.0 STRANDED!
I drove down the road to the autoparts, about 2 miles away and as I was about to pull in my tow haul light started flashing and tranny started shifting weird. All Temps were normal. Shut it off went inside and when I came out to start it the light was still flashing and now I have no throttle response. I'm stuck in the parking lot these are the codes I'm pulling.
on my edge scanner:
P0118, P0480, P0720, P0722, P1744, P2700, P2701, P2702, P2703
my obd2 scanner I have pics of codes attached. Can anyone please help?
update I disconnected the batteries for like 20 minutes reconnected and started up but every gear when I push the fuel pedal it's trying to go forward.
Also check gauges is illuminated where digital odometer is on cluster.
Old May 26, 2021 | 01:10 AM
udsuth78's Avatar
udsuth78
I'd start with the wiring connectors for the transmission and the range sensor.
Old May 26, 2021 | 08:19 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Yeah that looks like electrical...possibly wiring, but for THAT many codes either your transmission fell out or your electrical system took a dump.
Old May 26, 2021 | 10:12 PM
udsuth78's Avatar
udsuth78
It could be a complete system meltdown, but considering it was driving and running fine then suddenly freaked out i would guess a ground came loose or something along those lines. The 6.0 specific page should have wiring diagrams, with a little investigation you may find a common thread between all those systems.
Old May 27, 2021 | 02:09 PM
MoneyPit6O's Avatar
MoneyPit6O
Thank all of you I will start to trace down the electrical components and check. Is there a diagram anywhere I could reference and where's a common fail point or point of interest maybe where I should start?
Old May 27, 2021 | 07:59 PM
udsuth78's Avatar
udsuth78
Here is the 6.0 specific forum.
https://www.ford-trucks.com/forums/forum107/
cpobst
Apr 26, 2021 07:17 PM
joseh
Jun 6, 2015 03:21 PM
rmk1
Aug 30, 2013 11:46 AM
hhh100
Jul 4, 2011 12:03 PM
jeffmfly1
Oct 4, 2008 05:34 PM
