Lots of random codes
Ford Trucks BMS Battery Monitoring Systems - General Tech Tips - Lockdown Security | LDS Tech Forum (forumbee.com)
1. one (or more) of the batteries are failing
2. Alternator issue
3. Connection issue, such as a battery terminal or some such.
Get a Voltmeter and measure battery voltage after sitting for a day or two.
2. Alternator issue
Thanks
Your vehicle is fitted with a Motorcraft maintenance-free battery which normally does not require additional water.
When a battery replacement is required, you must use a recommended replacement battery that matches the electrical requirements of the vehicle.
Note: After cleaning or replacing the battery, make sure you reinstall the battery vent tube, battery cover or shield.
For longer, trouble-free operation, keep the top of the battery clean and dry.
If you see any corrosion on the battery or terminals, remove the cables from the terminals and clean with a wire brush. You can neutralize the acid with a solution of baking soda and water.
Because your vehicle’s engine is electronically controlled by a computer, some control conditions are maintained by power from the battery. When the battery is disconnected or a new battery is installed, the engine must relearn its idle and fuel trim strategy for optimum driveability and performance. Flexible fuel vehicles (FFV) must also relearn the ethanol content of the fuel for optimum driveability and performance.
To restore the settings, do the following:
- Apply the parking brake.
- Shift into park (P) or neutral (N).
- Switch off all accessories.
- Press the brake pedal and start your vehicle.
- Run the engine until it reaches normal operating temperature. While the engine is warming up, complete the following: Reset the clock. Reset the power windows bounce-back feature. See Windows and Mirrors. Reset the radio station presets.
See Audio System.
- Allow the engine to idle for at least one minute.
- Drive the vehicle at least 10 mi (16 km) to completely relearn the idle trim and fuel trim strategy.
Note: For flexible fuel vehicles, if you are operating on E85, you may experience poor starts or an inability to start the engine and driveability problems until the fuel trim and ethanol content have been relearned.
Make sure that you dispose of old batteries in an environmentally friendly way. Seek advice from your local authority about recycling old batteries.
If storing your vehicle for more than 30 days without recharging the battery, we recommend that you disconnect the negative battery cable to maintain battery charge for quick starting.
Battery Management System
The battery management system monitors battery conditions and takes actions to extend battery life. If excessive battery drain is detected, the system temporarily disables some electrical systems to protect the battery.
Systems included are:
- Heated rear window.
- Heated seats.
- Climate control.
- Heated steering wheel.
- Audio unit.
- Navigation system.
After battery replacement, or in some cases after charging the battery with an external charger, the battery management system requires eight hours of vehicle sleep time to relearn the battery state of charge. During this time your vehicle must remain fully locked with the ignition switched off.
Note: Prior to relearning the battery state of charge, the battery management system may temporarily disable some electrical systems.
Electrical Accessory Installation
To make sure the battery management system works correctly, do not connect an electrical device ground connection directly to the battery negative post. This can cause inaccurate measurements of the battery condition and potential incorrect system operation.
The reason I posted it in reply to the random codes, is if you don't reset your computer, it can cause issues from what I have read about it. I have no idea why his codes are happening, but thought others might learn something by mentioning it. If a FORD dealer changes your batteries, they have a way to hook directly into the computer and reset without doing these steps in the owner's manual.
