Stumbling Six
Old Jun 10, 2021 | 06:26 PM
  #31
Finality's Avatar
Finality
Originally Posted by SFaulken
it has to be a very thin wall socket, they sell a tool at most of your FLAPS, it's about eight bucks, last time I bought one.
Thanks a ton!
Old Jun 10, 2021 | 06:30 PM
  #32
SFaulken's Avatar
SFaulken
Just tell them you need a Ford TFI Module wrench, assuming they don't completely have their heads up their bums, they should know what you're talking about.
Old Jun 10, 2021 | 06:34 PM
  #33
Finality's Avatar
Finality
Just found a really weird socket that fit it. Pulled it out and there is a bunch of white paste behind it. Is that a normal thing? I have not seen anything like that yet on the videos and pictures of these things.
Old Jun 10, 2021 | 06:36 PM
  #34
Finality's Avatar
Finality
N/m. Just saw the small package that comes with this thing.
Old Jun 10, 2021 | 06:45 PM
  #35
torq'ta 5 8's Avatar
torq'ta 5 8
white paste is your heat sink paste, the tool is this
Old Jun 10, 2021 | 06:48 PM
  #36
Finality's Avatar
Finality
Thanks much!
Old Jun 10, 2021 | 07:21 PM
  #37
Finality's Avatar
Finality
New coil and ignition control module did nothing. Still no spark. Spark plugs are completely dry. Fuel pressure is at 50 when turned on and around 55 when cranking over. Parts store is telling me it may be a faulty coil out of the box and not telling the injectors to fire and no spark.
Old Jun 10, 2021 | 09:21 PM
  #38
Finality's Avatar
Finality
I am thinking a bad pickup in the distributor and/or crank position sensor.
Old Jun 10, 2021 | 11:00 PM
  #39
88n94's Avatar
88n94
You don't have a crank position sensor atleast that I know of. You did remember to hook the wires up when you replaced the ignition control module? I forgot once. You could check to make sure you have power up to the coil through one of the small wires hooked onto the coil with the ignition switch turned on.
It's pretty good when the parts store tells you a part may be faulty out of the box. I know this happened on here to someone very recently. where did you get the coil and ignition module and what brand were they?
Old Jun 11, 2021 | 05:33 AM
  #40
torq'ta 5 8
your PIP in distributor, how to test see #7-->Part 5 -How to Test the Ford Ignition Control Module (Fender Mounted)
Old Jun 14, 2021 | 05:03 AM
  #41
Finality's Avatar
Finality
I have done all of these tests and even switched out the distributor because i had one and still zero spark or fuel. I took the computer out and opened it to check the capacitors and they seemed fine. Could there have been a way the timing is so far out that it will not fire spark or the injectors? I don't know how that would get done but who knows at this point. Is there a fuel injector relay or is it all on the fuel pump relay? The relay they gave me at the parts store fits the spade pattern but is too big for the plug.
GoCamping
Mar 2, 2012 09:40 AM
moose4x4
Jan 31, 2010 10:06 PM
Tomget
1983 - 2012 Ranger & B-Series
May 29, 2008 04:28 PM
kevan b
Dec 30, 2005 07:29 PM
s_laviolette
Nov 19, 2001 03:23 PM
