Air bag light flickering
Old May 25, 2021 | 10:00 AM
scr8pin_f100's Avatar
scr8pin_f100
Hey all..I have a 1994 F-150 4x4 single cab truck. The air bag light was coming on and giving a code 12, which I know is low battery voltage..But recently it air bag light will flicker and be accompanied by a buzz, or what sounds like ham radio interference..
No codes, just a flicker. It does this for a couple minutes, then goes away and doesnt come back on..
I'm gonna check my grounds and all connections I can get to..Has anyone else had this issue?
Old May 25, 2021 | 10:05 AM
R&RFord's Avatar
R&RFord
The control module itself can go bad, but checking the connections and grounds is always a good place to start.
Old May 25, 2021 | 10:14 AM
scr8pin_f100
My initial reaction was the control module..but now the flickering has me questioning connections. Do you know if the buzz is a by product or is that usually associated with these air bag light issues? Perhaps there are more issues going at once?
Old May 25, 2021 | 10:21 AM
torq'ta 5 8's Avatar
torq'ta 5 8
see post #3 subford -->Ground Points - Ford Truck Enthusiasts Forums
Old May 25, 2021 | 10:24 AM
R&RFord's Avatar
R&RFord
If I recall the system is supposed to be able to chime... or beep as a secondary way to indicate trouble. But no buzzing...
Old May 25, 2021 | 10:26 AM
scr8pin_f100
Thank you! That will help
scr8pin_f100
Yes..the buzzing sounds like a dying chime..so maybe thats what it is
mlee
Mar 16, 2006 06:50 PM
claysyddad
1983 - 2012 Ranger & B-Series
Mar 15, 2004 02:25 PM
gwmontgomery
Electrical Systems/Wiring
Jun 29, 2000 04:36 PM
