Air bag light
Old Mar 10, 2006 | 04:47 PM
mlee's Avatar
mlee
Air bag light
Anyone know why my air bag light blinks three times and pauses while i'm driving could you tell me how to fix it?
Old Mar 10, 2006 | 04:57 PM
quicklook2's Avatar
quicklook2
it means that something is wrong with it.
Old Mar 10, 2006 | 07:10 PM
ncranchero's Avatar
ncranchero
Check it again. It should blink a 2 digit code. blink-blink-blink short pause blink-blink-blink long pause and repeat. After it goes through this several times it should stay steady illuminated. Does it? What year/model truck?
Air Bag Lamp Fault Code 33 = B1933 33 9 Passenger Air Bag Circuit Resistance High
Old Mar 11, 2006 | 10:14 AM
mlee's Avatar
mlee
year and model
'94 f-150 flare side and no it doesn't stop blinking it goes blink,blink,blink pause and repeats
Old Mar 11, 2006 | 12:30 PM
wildcard30's Avatar
wildcard30
ABS Flashing Fault Code Table
I had the same problem with my 1994 Flareside...
Blinking airbag light...
Turned out to the airbag clock spring.
Just before this happens, you could hear a metallic rubbing sound inside the steering wheel.
From what I have been told, a clock spring failure is common for F-150s of that model year.
Here's the trouble code chart
CODE COMPONENT/FAULT
12 Low Battery voltage
13 Air Bag Circuit Shorted to Ground
14 Front Air Bag Sensor and Bracket Circuit Shorted to Ground
21 Rear Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
22 Rear Air Bag Sensor and Bracket Output Circuit Shorted to Battery Voltage
23 Rear Air Bag Sensor and Bracket Circuit Input Feed/Return Circuit Open
24 Rear Air Bag Sensor and Bracket Output Feed/Return Circuit Open
32 Driver Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
41 RH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
42 LH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
44 RH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
45 LH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
51 Air Bag Diagnostic Monitor Internal Thermal Fuse - Fuse Blown Due to Intermittent Short to Ground
52 Backup Power Supply - Voltage Boost Fault
53 Front Air Bag Sensor and Bracket Circuits Resistance to Ground or Air Bag Diagnostic Monitor Fault
- Rapid Continuous Flashing of Air Bag Indicator (No Fault Code) All Primary Air Bag Sensors Disconnected
- No Air Bag Indicator - Inoperative Indicator Circuit or No Battery Positive Voltage to Air Bag Diagnostic Monitor
- Continuous Air Bag Indicator - Air Bag Diagnostic Monitor Disconnected or Inoperative
Hope this helps....
Old Mar 11, 2006 | 12:52 PM
wildcard30's Avatar
wildcard30
If it's the clock spring, here's the general procedure to remove and replace it..
Air Bag Sliding Contact
1. WARNING: THE BACKUP POWER SUPPLY ENERGY MUST BE DEPLETED BEFORE ANY AIR BAG COMPONENT SERVICE IS PERFORMED. TO DEPLETE THE BACKUP POWER SUPPLY ENERGY, DISCONNECT THE BATTERY POSITIVE CABLE AND WAIT ONE MINUTE.
Disconnect the battery positive cable and wait one minute for the backup power supply energy to be depleted.
2. Make sure the vehicle's front wheels are in the straight-ahead position.
3. Remove the driver side air bag module (043B13)
4. Remove the steering wheel (3600).
5. CAUTION: Do not apply excessive force to the air bag sliding contact (14A664).
Turn the air bag sliding contact clockwise until it stops.
6. Rotate the air bag sliding contact counterclockwise 2.75 turns.
7. Align the marks on the air bag sliding contact with the marks on the outer housing.
8. Install the steering wheel.
9. Install the air bag module as described in Module, Driver Side Air Bag, Removal and Installation in this section.
10. NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the strategy.
Connect the battery positive cable.
11. Verify that the air bag indicator is operative.
Old Mar 16, 2006 | 02:54 PM
dlpbap's Avatar
dlpbap
I have a 2000 Ranger. Air bag light flashing like described in messages. This past two weeks we have had several wet slushy snowstorms. Could water have splashed somewhere and caused short? Do any of the fuses under the hood have anything to do with air bags?
Old Mar 16, 2006 | 06:22 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 16, 2006 | 06:50 PM
wildcard30's Avatar
wildcard30
What code does it flash??
