06 f250 need help
Old May 25, 2021 | 09:24 AM
Ginotwotimes's Avatar
Ginotwotimes
06 f250 need help
So I have 06 f250 and recently it’s been acting up. When shift to drive or reverse sometimes the rpms will surge and sometimes it will shutoff when I go into drive or reverse. Also sometimes dies at stop signs and all that. Threw code p1102 and code p2290. Lack of power but once you get up and going it drives fine.
Old May 25, 2021 | 11:01 AM
xcrsp440's Avatar
xcrsp440
What have you done about the codes. Both would tend to support your stalling and lack of power.
Can you show your injector pressures and MAF readings?
Old May 26, 2021 | 09:08 PM
IHateCommieCars's Avatar
IHateCommieCars
Both of those codes can be thrown by bad fuel filters, and cause power issues like you describe. When's the last time you replaced? Do you use Motorcraft filters? The 1102 is usually either the sensor or the wiring/connector, or that it just got left unplugged. The 2290 points to the IPR valve, or it could be wiring as well. What reading do you get for Vref?
champlainl
Mar 9, 2016 10:26 PM
mrwrench
Jan 21, 2011 06:21 PM
