Voltage Regulator
Old Oct 29, 2003 | 05:35 PM
79 250 lariat 4x4's Avatar
79 250 lariat 4x4
Voltage Regulator
does the voltage regulator ground itself to the truck through it's metal casing or is it grounded through wires?
Old Oct 29, 2003 | 05:37 PM
luckild's Avatar
luckild
could be either, what engine do you have and how many wires are at the regulator?
Old Oct 29, 2003 | 05:52 PM
Franklin2's Avatar
Franklin2
Through the metal case of the reg.
Old Oct 30, 2003 | 11:02 PM
79 250 lariat 4x4
well it's a 400.. so if it grounds through the metal case then it would have to be bolted fairly securely to the truck itself to get a good ground.. but the bolts have nothing to grab.. any suggestions on that?
Old Oct 31, 2003 | 12:13 AM
sparky's Avatar
sparky
You could always add a wire from the case direct to the battery negative, then it wouldnt matter if the mount bolts were loose.
Old Oct 31, 2003 | 05:02 PM
79 250 lariat 4x4
hmm... i dunno about that i am not to into half-assing stuff.. maybe just a couple of bolts that are a size bigger?
Old Oct 31, 2003 | 09:05 PM
Franklin2's Avatar
Franklin2
Adding a wire from the case of the regulator, to the negative of the battery, or the sheetmetal of the the fender, or the metal of the engine block, is a perfectly legitmate fix for older vehicles that have problems with corrosion and vibration.
Forcing larger bolts in the holes would probably work, but I think would also fall into your half-****** catagory.
