So my 2021 arrived missing this plug in the door jamb. I had difficulty identifying the part number via Ford, and my Ford dealer, to order a replacement. I found the following information and wanted to share it.
Ford uses a Caplugs BPF 15/16 plug for this spot on all 4 doors. Unfortunately this plug is only available (from what I could find) in large quantities at any online supplier, like 200 or more. Also this plug fits a little loose, hence why falling out is common.
So I found that a Caplugs BPF-1" will fit perfectly, per Caplugs spec sheet it is slightly larger than the 15/16 but pretty darn close and available widely online in small quantities like 5 to 25 for a few bucks. I bought mine on Amazon and it snapped in tighter than the original and once installed it looks nearly identical to the 15/16 plug on the other doors. The tighter fit is a bit harder to install but once it is never falling out. I replaced all 4 with the large 1" and chucked the other three 15/16 plugs.
I could not find this information anywhere on the forum, nor on the SuperDuty Facebook groups, so I am sharing it here to add to the knowledge base.
I just checked my 2020 and it is missing the drivers rear door. Do you have a link to the ones you purchased. I would like to replace all of mine as well.
I have been trying to find the part number for this plug myself.
Have a 2020 F350 and it's missing the driverside rear door plug.
Can you give me the part number you purchased.
In the first post he says Caplugs BPF-1" , did you try that?
My driver's side rear door plug kept falling out. Finally fell and missed it, so ordered a pack of these and they fit nice and tight. Will eventually replace the others as well.
