Those are essentially the same; the 62379 uses pedestal type rockers, while the 60329 uses studs with guide plates for the pushrods. The stud version can potentially accommodate valve lift beyond .600 inch with the right springs. But that would be pretty extreme.
Just using a factory head? I was hoping to avoid a bunch of machine work.... I think I could do the port and polish myself, but honestly raisng five kids, it would take me a year to get to.
If you're good at port work, just remove the Thermactor bumps inside the exhaust ports and port match the walls and roof to the header gasket. If you're going to do a valve job, then bowl blend all this down to the valve seats. Then just do a clean up on the intake sides. The exhaust side of SBF heads were always the bottleneck to performance. I did a set like this and it really turned out well in a 3500 lb Ranger with a B cam(with 1.7 rockers) and a C9OX intake. Pulled to 6500.
You might be surprised how little if any the thermactor bumps hurt exhaust flow. Don't concentrate too much effort on the exhaust side because the intake is where the power is made.
Either way, I dont have a set of stock heads to mess with currently, and honestly with kids ranging from 17 to 1, with another truck in build in progress for one of the boys, I dont have the time to sit down and spend hours grinding. I know I am going to have to buy heads, so it makes the most sense to buy one of the above mentioned after market sets ready to go, instead of buying stock heads that need all the work. What I am out in an extra couple of hundred dollars I save in time. I appreciate the feedback, honestly, but stock heads just simply are not a choice.
What I mentioned doesn't take hours. Maybe two at the most with a good bit.
That's not an opinion. If you've ever had one of those heads on the flow bench you'd feel the same way. The thermactor bump is directly behind the exhaust valve stem where it isn't really in the flow path. Removing it entirely just adds more turbulence. So go learn a few things instead of parroting crap information.
It IS your opinion. I'm not parroting anything. You how ever post some real whoppers here. We've seen your kind before here. They come and go regularly. Some one disagrees with them, and they puff up and put them down with BS. If you don't like what I post then do what your mom said, keep it to yourself.
I appreciate everyone's feedback.... I would really like to keep this thread open and collect info. The discussion is a moot point as I do not have a set of stock heads to mess with right now like I said. Its more than just the time for porting, its the time to go find them, pull them, break them down, get them done up at a machine shop, and do all the valve work. I just got done doing a valve job on a set of 5.4 heads.... Im just going to buy something off the shelf that I can bolt on. that is a part of this I have in the budget. So unless a set of ready-to-go GT40s lands in my lap, Im just buying aluminum heads.
Why don't you give me a few examples of these "whoppers".
I can show you actual flow bench and dyno results from factory Ford heads with porting work and that's why I posted that about porting. For many years it was "common wisdom" about how factory Ford heads needed all this attention on the exhaust side to run well and those ideas have largely been proven false in actual real world testing.
Again this is your opinion, you're discounting everyone else who found otherwise.
Why don't you guys start your own thread to hash this out. The personal back and forth isnt adding anything useful to my question at this point.
Normally it's the veteran members that have to tell the new members to settle down, not the other way around.
The AFR 185 Enforcers that sethahoward linked above are a solid choice on a budget. The problem with all of the junk chinese heads is usually not the castings, it's the hardware in the heads and the machine work for the valve guides, seats, and studs. AFR takes some fairly inexpensive castings, machines them, and puts good hardware in them.
Sweet, thats good info, and I appreciate. I actually just found out I can order GT40's from autozone for $400 each..... but I will probably still go with the AFR's. I see so much info on cam profiles I am really struggling there. Im hoping to strip the block down this weekend and check bores to see if they are all still round and if they have been worked over before. Would be nice to just have to put new bearings in and run with what is there. Trying to do an engine swap in a '99 for my son has slwoed me down quite a bit. We got the truck for almost free and a good motor for not much more... He isnt allowed to drive the '95 anymore.
