increasing mpg
Old Dec 10, 2003 | 09:49 PM
  #31
muscletruck7379's Avatar
muscletruck7379
Originally posted by pdqford
A well tuned distributor has quite a bit of timing advance built into it at light to moderate cruise because the combination of EGR (inert gases) + air/fuel needs more time to burn and you need to complete the combustion process by about 23 degrees ATDC to maintain reasonable power AND fuel mileage. Thats also why EGR equipped engines are very prone to serious pinging if the EGR valve fails (or is blocked off, or the internal passages become plugged with carbon deposits.)
HA! my bronco will barely run with that little advance!
Old Dec 11, 2003 | 10:55 AM
  #32
pdqford's Avatar
pdqford
How much advance you need is as much as it takes to complete the combustion process by 23 degrees AFTER top-dead-center. If your Bronco has slow burn heads, low compression, and good EGR flow at light throttle, it may need 50 to 60 degrees advance at the crank (thats mechanical advance + vacuum advance + base timing) so that the combustion process is completed by 23* ATDC.
Old Dec 11, 2003 | 04:47 PM
  #33
muscletruck7379
well that actually sounds about right cause this things curve starts at about 30
Old Dec 11, 2003 | 06:49 PM
  #34
Banditt's Avatar
Banditt
Check your cat' converter, if its fairly plugged, I'd have it changed or removed. I just take them right out if there isn't a downstream O2 sensor on it.
75_92_95
1978 - 1996 Big Bronco
13
Jul 22, 2015 08:47 AM
Parsedout
Jul 20, 2015 02:18 PM
Me_Rock
17
May 7, 2015 09:02 PM
640 CI Aluminum FORD
Computer Chips & Tuners
Apr 23, 2011 04:55 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
16
Jul 16, 2007 09:40 PM
