overheating problem
Old Dec 9, 2003 | 05:52 PM
Banditt's Avatar
Banditt
overheating problem
Ok, I have this little problem. My 1990 ford truck (302 engine) is overheating. It only overheats when you take it on a long streatch about 10-20 miles. It doesn't overheat when driving in town or sitting and idling for hours.
Now I've replaced the thermostat, put in a brand new Radiator, and a new cluch fan. I am getting enough air flow (no dirt plugging the airway). I do though have white oil on the inside of my oil cap (would give me the thought of a head gasket) but nothing in my oil. I was told that white oil is just from condisation. I've done a rad compression, and I don't lose any pressure. Would an leaking intake or Plenuim cause an overheat? Any Suggestions?
Old Dec 9, 2003 | 09:39 PM
f100guy's Avatar
f100guy
maybe you accadentally put the thermo in backwards. is your fan shroud there. if your timing is off it will overheat sometimes
Old Dec 9, 2003 | 09:40 PM
Banditt's Avatar
Banditt
Check those already. They are good. Thanx for the reply
Old Dec 10, 2003 | 12:22 AM
f100guy's Avatar
f100guy
are you using a hotter spark plug than stock. are you losing water
Old Dec 10, 2003 | 06:35 AM
victorcharlie's Avatar
victorcharlie
I seen stopped up catalitic converters cause overheating problems. How about the waterpump? Think it might be bad?
Old Dec 10, 2003 | 09:24 PM
gonetruckin's Avatar
gonetruckin
you know im not sure but your water pump may be pulling one of those tricks where it only works on certin conditions.. now i havent had a water pump to do that on me but a lot of things can do that. so it is possible that it wont work when your at highway speeds? weird stuff like that can happen! you might want to check it out
Old Dec 11, 2003 | 06:53 PM
Banditt's Avatar
Banditt
It turned out to be a faulty new thermostat that I just put in. Thanx for all the replys though.
