Starting issues.
Old May 18, 2021 | 05:54 PM
Duckf00t's Avatar
Duckf00t
Starting issues.
Alrighty folks since I'm not a mechanic but a redneck with tools here it goes.
'93 f-150 5.0 when it's cold starts right up runs just fine. Will run just fine until you shut it down...then you better have something to do for about 6 hours. If I try to crank it to start while hot, it'll wear the battery down trying. Leave it for few hours it's difficult but will start.
Ok what hasn't helped list:
New fuel filter, plug wires, plugs, map sensor, distributor cap and rotor. It's got 2 tanks one the fuel pumps was already bad. The other one went so new fuel pumps.
So what's left? Coil or if it's got one ignition control module?
Old May 18, 2021 | 06:22 PM
kevinv10's Avatar
kevinv10
Whan this happens, if it turns over slower than normal, then i would crawl under the truck with a hammer, and whack the starter a few times. If it starts, obviously bad starter. Seen this quite often in fords. If this doesn't work, I would still have the starter checked. Could be heat sink in the starter.
Old May 18, 2021 | 07:12 PM
Duckf00t's Avatar
Duckf00t
Well I forgot to mention new starter a year ago. It doesn't really turn slow but does seem like it's laboring more than cold.
The truck was my son's he gave it to me tired of fighting the non start after warm. He said was doing that before starter change, after was brand new.
Old May 18, 2021 | 07:16 PM
SFaulken's Avatar
SFaulken
Check your grounds, and the condition of your battery cables. especially the one that runs between the solenoid and the starter.
Old May 18, 2021 | 07:21 PM
Duckf00t's Avatar
Duckf00t
Yep that was a thought I had, when changed out fuel pumps went ahead got all the grounds cleaned and checked. When we replaced starter he got new grounding wire, with new battery.
Old May 18, 2021 | 09:50 PM
TooManyMIce's Avatar
TooManyMIce
Doesn't sound like a starter problem. Maybe an injector or the fuel pressure regulator is leaking gas into the manifold, flooding it until the gas dissipates or runs past the rings. How's the oil smell?
Old May 19, 2021 | 01:24 PM
Duckf00t's Avatar
Duckf00t
Oil smells normal, no gas smell. Would it be a good test get it warmed up shut it down have helper spritz bit of starter fluid in intake. That tell me if it's fuel or fire?
Old May 19, 2021 | 02:00 PM
sandymane's Avatar
sandymane
That sure would tell you about a possible fuel issue, which is top on my thoughts. Or, you can check fuel pressure with a rented tool at an auto parts store. Good idea.
Old May 19, 2021 | 04:06 PM
torq'ta 5 8's Avatar
torq'ta 5 8
Try checking for codes, even if CEL isnt on, could be stored codes.
Old May 19, 2021 | 04:16 PM
TexasGuy001's Avatar
TexasGuy001
Check to see if it holds fuel pressure after shut down or if the pressure bleeds off quickly. I had this happen on my previous truck and it was leaky injectors. Using a spark tester that just installs between the plug and the wire would tell you if you have spark or not.
Old May 19, 2021 | 06:07 PM
TooManyMIce
I've used the starter fluid test on engines that didn't have fuel, but I wouldn't expect it to do anything on an engine that's flooded. Texasguy's test with the pressure gauge sounds like a better way to go.
Gryphon1962m
22
Apr 24, 2022 11:27 AM
TallPaul
Aerostar
23
Sep 27, 2013 01:56 PM
Oldblue1990
Dec 16, 2011 09:22 PM
civilwarcollector
Dec 20, 2007 11:10 AM
CMW
Bronco II
Sep 30, 2006 06:06 PM
