96 302 roller block
Old May 18, 2021 | 02:29 PM
retired ironworker's Avatar
retired ironworker
96 302 roller block
Can a 1996 302 without distributor be made to accept a distributor?
Old May 18, 2021 | 02:53 PM
Conanski's Avatar
Conanski
Yes, the block never changed in this regard. The EDIS sensor used in the Explorer 5.0 is essentially the lower half of a distributor with that sensor mounted on the top of it, pull that out and a standard 302/5.0 distributor will drop right in.
Old May 18, 2021 | 02:55 PM
retired ironworker
Thanks for this info, I'm going to use this in my 66 F100
Old May 23, 2021 | 10:21 AM
baddad457's Avatar
baddad457
You will need a steel timing gear on the distributor to match the steel billet roller cam here.
dogstar
Jan 5, 2011 01:40 AM
lwhitcomb
Sep 22, 2007 07:32 PM
PigFarmer
Mar 20, 2002 01:17 PM
