My 96 F!50 has a OBD2 302, if your heart set on having OBD2 and a 302 a 96 f150 would be your only choice. I believe mustangs were no longer using a 302 in 96, although I've never seen one there may be a few 302s in f250s from this generation, I know they used 302s in a few older f250s, just not sure if they used them in 96.
Explorers used them up to the body style change in '02. That may be a better choice as one from the first year of OBDII probably won't have as many programming capabilities, just a guess. You'll probably have to figure out basically what you want to do and if the system if capable of it.
The 1996 was the last year for the 302 in any FORD with a distributor.
So I would think that 1996 F150 is your only choice.
The Explorer did have a 302 up to 2001 but it was an electronic distributorless ignition system (EDIS) controlled by an electronic engine control (EEC) integrated into the powertrain control module (PCM).
The PCM out of one of these would have different inside parts and would not be an option for you.
Why wouldn't an Explorer engine and PCM be an option? It's going in a project car; things will have to be modified regardless of what he uses.
