Sponsored by: Real Truck
Help!
Old May 17, 2021 | 11:46 AM
jcw88910's Avatar
jcw88910
Help!
Ok hey guys I got a problem, I drive a 2003 Ford f250Sd XL 5.4l v8 4x4. Lastnight I ran out of gas and over heated, due to being where I was at when it happened I had to fill it with water. I had to fill again this morning otw to work. I dont know why it is o er heating, I just put coolant in bbn it two weeks ago. Any suggestions??
Old May 17, 2021 | 08:29 PM
5am's Avatar
5am
is it leaking water/coolant onto the ground, did you check the oil and see if it is milky?
Old May 18, 2021 | 07:50 AM
Mike1's Avatar
Mike1
Sounds like you either have a leak or possibly a blown head gasket, you stated you over heated it, possibly warped head and gasket letting the water / coolant out through the exhaust side.
Old May 18, 2021 | 07:17 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Pop your oil cap and look for a milky fluid. If that's the case you have a blown head gasket and coolant is leaking into the oil.
Old May 18, 2021 | 07:40 PM
Mike1's Avatar
Mike1
a milky film on the oil cap could be due to overnight condensate not necessarily a blown head gasket.
Old May 18, 2021 | 07:45 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Does that happen? I've never seen that before.
Old May 18, 2021 | 08:12 PM
Mike1's Avatar
Mike1
Happens when you don't run your engine long enough to get the moisture out of the oil...my trucks have been doing it for years because they sit for months at a time then get used for a home depot run which is only about 6 miles for me, then it sits again...I don't use it like I did when I worked construction everyday.
zjmj17
Dec 10, 2016 05:01 PM
ukisash
Oct 25, 2015 08:32 PM
blueeyedfordguy
1997 - 2003 F150
Oct 22, 2013 11:49 PM
weekendwarriorfsw32
Nov 4, 2007 01:35 PM
gotdiesel
General Automotive Discussion
Jun 20, 2006 11:16 PM
