battery voltage fluctuating
Old May 17, 2021 | 11:03 AM
gdhillon's Avatar
gdhillon
I have a 13 f350 6.7, weight loss with proven tunes.
One of the things I monitor on my ezlynk app is battery voltage. I usually have 14.4 running, past month or so I have noticed it slowly drop (seems like it drops with higher rpms) to as low as 13.7.
It has been a steady drop, for awhile it it was 14.3-14.2, then 14.2-.1 and so on. I cleaned my battery terminals to see if that would help, I got 12V at both batteries with them disconnected from the truck.
Some background on the truck, I bought it in august (emissions were intact at that time) . Shortly after I bought it I was getting an intermittent battery light, which soon turned to a steady light. Dealer sent me to a local shop (dealer is in a different town) that replaced alternator with a FOMOCO part as it was diagnosed with a bad diode, they also rerouted an alternator wire from my understanding. (this work was 21ishK miles ago)
Has anyone else experienced this issue?
Thanks in advance!
Old May 17, 2021 | 11:53 AM
Gyppo Logger's Avatar
Gyppo Logger
I noticed this on mine, bought 2 new maintenance free glass mat batteries and as time went by the less the charge they took (voltage drop). I chocked it up to the batteries getting older.
Old May 17, 2021 | 11:55 AM
jollyrogr's Avatar
jollyrogr
Age of batteries shouldn't affect the voltage output from the alternator though, right?
Old May 17, 2021 | 02:18 PM
Squirrel13's Avatar
Squirrel13
My new 2020 F350 6.7 with the dual alternators fluctuates 13.7-14.5. I believe most modern vehicles use "smart" alternators that can vary the voltage and current based on demand. I'm not sure if the 13 had those but it wouldnt surprise me
Old May 17, 2021 | 05:18 PM
Just Strokin's Avatar
Just Strokin
Looks normal to me. My 2015 also ranged from 13.7 to 14.3 even with new batteries.
Old May 17, 2021 | 06:22 PM
ChiefMongo's Avatar
ChiefMongo
Batteries and alternator output.
a shorted cell will effect output of the alternator. And performance of the vehicle
Old May 17, 2021 | 06:27 PM
ChiefMongo's Avatar
ChiefMongo
Thanks in advance!
never had a bad diode on any 6.7. Not saying they don’t exist. There are 4 wires to the alt. Gen com gen mon 12 in 12 out. Never had an output issue but the com mon and in wires have issues. Some dealers sell the harness. I always overlay all three of those for one failure. (The other two will happen). Bad design. Once the cel is on you’ve lost another one of the three wires.
jollyrogr's Avatar
jollyrogr
A shorted cell sure, but not necessarily due to old age...
Old May 19, 2021 | 07:47 AM
speakerfritz's Avatar
speakerfritz
I had the battery light problem and the infamous wire by pass done by the dealer fixed it.
my battery voltage on new batteries are low 14's on start up and mid 14's after the engines run for a few minutes.
my recomendation is just to have your batteries tested for cranking amps...can be done at any auto parts store.
66with352
1997 - 2003 F150
Aug 11, 2024 10:42 PM
Cody Mitchell
Apr 5, 2021 10:18 AM
Tylus
Sep 18, 2013 03:17 PM
brf2
Dec 16, 2006 10:56 PM
edog11
13
Mar 21, 2005 09:49 PM
