Just installed eight ad injectors now I have an intermittent check engine soon light. Doesn’t stay on but it’s annoying. Engine runs great . Could it be because I put an ad injector in #8?
Does the CEL come on when the turbo is producing a lot of boost, say around 25 PSI?
Does the engine defuel a bit then pick back up a short time later?
We've seen a customer's vehicle hold weird injector codes until they disconnected the batteries. Clearing the codes wasn't successful. Worth a shot. Are these new or reman injectors?
ran it hard on the way to work about 50 miles and by the time I got there the light has been staying off .
Great news!
We usually recommend at LEAST 50 miles of "spirited" driving in order to clear the air out of the system. We like to see upwards of 100 miles though. Rosewood is a solid shop and a good choice for injectors, you've done well.
