Sponsored by: Real Truck
2015 F250 steering issues
Old May 16, 2021 | 11:56 AM
Debk97's Avatar
Debk97
I've had the truck to a mechanic and the whole front end checked out. He couldn't find any reason it was giving me fits. alright so here's the issue. when driving down the road the steering will get tight and start pulling. I have to turn the steering wheel the opposite direction of the pull until it releases. once it releases the truck bounces from side to side. Imagine your a ball between 2 boards and just bouncing off each side. It will stop after a min(feels a lot longer) I'm at a loss and so is the mechanic. Anyone have this issue.
Old May 16, 2021 | 01:25 PM
jsukey's Avatar
jsukey
Sounds like you may have a brake caliper that’s starting to freeze up on you.
Old May 16, 2021 | 05:50 PM
Djosbun's Avatar
Djosbun
No, I haven't had this issue. Precious vehicles I repaired had bad steering racks or improperly torqued ball joints.
-- Dave
Old May 16, 2021 | 05:51 PM
Djosbun's Avatar
Djosbun
This is easily found with a temperature gun. I would hope the mechanic would have found this quite easily even if he were new to the trade.
-- Dave
Old May 16, 2021 | 10:49 PM
Debk97's Avatar
Debk97
Its not an all the time occurence,driving tonight it started acting a fool. I pulled over put it in park and turned the wheel all the way to the right and then left. I could hear something pop and then it drove fine. Short of blowing this beast up lol. I'm waiting on a new gear boprobably not the problem) I've already done tie rods and steering stabilizer. I hate to keep throwing money into this truck.
Old Nov 3, 2022 | 08:42 AM
1963fairlane5002dr's Avatar
1963fairlane5002dr
4wd Low
I can relate to the ball bouncing back and forth, I've been through every part on this frontend. Wondering if that's just the way they are? Thanks
Old Nov 3, 2022 | 08:53 AM
1963fairlane5002dr
4wd Low
Thank you for your input, if it is a stuck caliper or collapsed ruber brake line, i'd think i'd see evidence on the brake pads. Excellent reply tho.
Old Nov 3, 2022 | 10:33 AM
Mike1's Avatar
Mike1
Had the same thing going on with my 03 F350 replaced ball joints, tie rods, Links and hub assemblies. Then I adjusted the Gearbox and it helped a lot. I sometimes still get to where the steering gets heavy and it'll pull to the right for a little while, then if I turn a corner it'll be fine. So the next step for me would be to replace the gearbox.
Ty.redbeard
Oct 26, 2022 10:05 AM
scsi6
Jan 14, 2016 11:14 AM
rmurray
Oct 27, 2012 08:56 AM
4beatg8
Sep 7, 2010 12:24 PM
schmittyhappens
Sep 10, 2006 08:09 PM
