Program your Isspro EV2 gauges - Attribute programming cable share
Old May 13, 2021 | 10:41 PM
BWST's Avatar
BWST
Got Data?
A while back, after installing 2 Isspro gauges in my truck, I noticed the backlight brightness was not even between the two. @SkySkiJason graciously sent an attribute programming cable to me. That cable, and some downloaded software from Isspro, allowed me to dial the brightness in. This is the 'before' shot:
Details on how to do this in post #341 of my maintenance thread:
https://www.ford-trucks.com/forums/1...l#post19734921
If you have EV2 gauges, and would like to program backlight levels and alarms, PM me your address, and I'll sent it to you. Rather than return the cable to him, Jason suggested we make it available to those who could use it. We can track where the cable is in this thread, and post any questions related to it's use.
Old May 14, 2021 | 03:54 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I love this community!
Old May 14, 2021 | 07:37 AM
ScaldedDog's Avatar
ScaldedDog
This is a great idea. We might also want to share settings used to make the EV2's match the dash lights, as I found the correct setting non-intuitive. Setting "Dimmer Max" to 80, from the default of 18, did the trick for me, and now it matches without flickering.
Mark
Old May 14, 2021 | 08:55 AM
BWST's Avatar
BWST
Got Data?
Mark
I agree, Mark. I tried 20, then went with 40 for "Dimmer Max" and probably could have gone a bit higher on this number. A higher number to dim the gauge more seems non-intuitive to me as well.
Old May 14, 2021 | 09:19 AM
SkySkiJason's Avatar
SkySkiJason
Thanks for helping share the cable Jeff!!!
Old May 17, 2021 | 07:58 AM
bsiliani's Avatar
bsiliani
Temporarily, for now I wired my Isspro yellow wire directly to the illumination fuse.
I have noticed no dimming or very bright gauges. Seems to be perfect light output..
But, I don't like tying into fuses for juice so following thread.
BTW, there is NO literature from Isspro on how to tweak their Iv2 gouges. I am curious on how to do that.
Old May 17, 2021 | 09:37 AM
SkySkiJason
I tap the brown wire behind headlight switch for 12v with running lights/headlights. It doesn’t hurt to add one of the 1 amp fuses from the gauge kits here.
Tweaking is done via this attribute programmer cable and software on your PC. You can set alarm limits and change the brightness of gauges.
Old May 17, 2021 | 09:52 AM
SkySkiJason
ISSPRO.com
With this, you can use the gauges to turn stuff on/off. I use this to activate 2nd OEM fuel pump in high HP applications.
You could turn on electric fan for trans cooler or someone could turn his CAC mister on with EGT.
Old Oct 20, 2021 | 02:11 PM
BWST's Avatar
BWST
Got Data?
@Stebo1 reached out to me for info on this cable - I'll be sending it to him shortly.
Old Oct 22, 2021 | 05:31 PM
Gaugepro's Avatar
Gaugepro
These programming cables should come with the "kit" when you order from your vendor. I no longer sell anything but when I did all my Isspro kits came with the programmer.
Are vendors not including this?
Old Oct 22, 2021 | 08:10 PM
Stebo1's Avatar
Stebo1
4wd Low
I can confirm that vendors arent including this. They offered to program it for me if I covered shipping.
Old Oct 22, 2021 | 08:46 PM
helifixer's Avatar
helifixer
many year ago when I did mine I got the cable with the gauges. I think I bought them from Clay at Riffraff.
I had totally forgot about the cable until I read this thread. I am sure I put it somewhere safe.
Old Oct 22, 2021 | 09:34 PM
kbeefy's Avatar
kbeefy
I had no clue this was a thing. Does this mean I can program the red led on my EGT guage to turn on at a preset reading?
I always wondered about that light that proves out when I switch on the ignition...
Old Oct 22, 2021 | 10:54 PM
SkySkiJason
Yes...,,,,
Old Oct 23, 2021 | 01:06 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
As a vendor I can tell you the kits we sell direct from Isspro do come with the cable. There is also instructions on their website for programing + you can call and talk with their engineer if you get stumped.
