Shock question
Old May 8, 2021 | 09:03 PM
JSPEX's Avatar
JSPEX
Shock question
I need to replace the shocks on one of my 2000 ex's. This one has the v/mod b springs. Pretty sure I'm going with the kyb monomax after seeing them recommended frequently on here. My question is whether to just get the ones for an excursion or if the V/B's mean I should get a different length?
Old May 9, 2021 | 03:13 PM
JSPEX's Avatar
JSPEX
Anyone have any feedback on this? I've been searching but can't seem to find the answer. I'm thinking new shocks would need to be longer with the v/b springs and I don't want to order the wrong ones....
Old May 11, 2021 | 12:13 PM
EXSwap's Avatar
EXSwap
What's your ride height? Measuring from the center of the hub to the wheel well.
Old May 11, 2021 | 03:51 PM
JSPEX's Avatar
JSPEX
23 1/2" front, 24 1/2" rear. I got to looking through the tech folder and found some info that makes me think I need to get the f250 fronts and the excursion rears.
Old May 12, 2021 | 12:26 PM
EXSwap's Avatar
EXSwap
You might also go through this thread to see what folks are doing if you haven't seen it:
https://www.ford-trucks.com/forums/1...easurents.html
Old May 13, 2021 | 06:25 PM
Flyboy1100's Avatar
Flyboy1100
your measurements are pretty dang close to my 210k almost worn out Original springs measurements, are you sure you have V/mod B?
My new U’s are 24.50 front and mod B are 26.0
Old May 14, 2021 | 09:06 AM
DavenTn's Avatar
DavenTn
Typically the spring change accounts for 2" increase in static height.
03X
Dec 8, 2015 03:41 PM
Iaff113
Mar 28, 2014 05:28 PM
PERFORMANCE RED
Nov 25, 2008 01:14 PM
esoteric781
1978 - 1996 Big Bronco
Jan 7, 2005 02:50 AM
