new 92 explorer
Old Oct 29, 2003 | 10:19 AM
the_ottogz's Avatar
the_ottogz
new 92 explorer
I just got an explorer from my father that just passed away, its a 92 with 99k miles on it and a V6 4.0. Interior and exterior look great. but the engine don't sound to good. It also has a problem that when i accelerate fast!! It starts choking badly almost to the point of dying, I think it could be a few things, fuel pump, throttle position sensor, or injectors. Can you please tell me what i should check before i take this to a mechanic, it isn't worth too much, I would love to drive it for a second car to work, i only work 5 miles away from home. Can anyone give me some ideas on what to do with it before i get rid of it.
Thanks
George
Old Oct 29, 2003 | 10:35 AM
CobraXP's Avatar
CobraXP
Welcome to FTE ottogz!
What doesn't 'sound' good? Do you have a Check Engine Light on?
I would suggest a good tune-up to start - plug, wires, fuel filter, air filter. Those 4 things can make a world of difference and could be affecting the throttle response.
Let us know!
Old Oct 29, 2003 | 08:20 PM
the_ottogz's Avatar
the_ottogz
no check engine light, but it sounds like it might be a lifter tick or a hole in the exhaust somewhere, that i could live with, oil pressure is good, and exhausts are pretty cheap, im just worried about the engine choking, it will cost me a few hundred to transfer the title, and another few hundred to fix is kinda too much, tune up should be cheap, i will try that, but if that doesn't work i'll have to take it somewhere, thanks for your fast reply
Old Oct 30, 2003 | 11:13 AM
CobraXP's Avatar
CobraXP
Sounds like you might have either an intake or head gasket leak. The 4.0's are notorious for having leaks like this. I would start with the tuneup and see how it goes. If you still hear the noise, I might stop by somewhere and get a few prices and evaluations on the leak...
Old Oct 30, 2003 | 04:28 PM
Jharger's Avatar
Jharger
Nope - best guess is to first clean the mass air flow sensor. You can find a simple procedure at this page under "engine pinging"
http://www.glue.umd.edu/~singletn/exp.html
It sounds like your case may be extreme if you're past the pinging stage.
gas6999
23
Jan 20, 2014 05:07 PM
jdadamsjr
Sep 22, 2013 10:52 PM
geoaigel
Feb 28, 2010 03:24 PM
geoaigel
23
Jun 1, 2008 10:08 AM
Waxy
Mar 31, 2003 09:23 PM
