Running board Low clearance concerns
Old May 6, 2021 | 10:29 AM
revamp1953f100's Avatar
revamp1953f100
Question Running board Low clearance concerns
After modifying our 53F100's chassis to lower it we now have concerns that the clearance when traversing over speedbumps or other hi spots in our routes will result in bottoming out and scraping the running boards and other under carriage parts like mufflers and battery. The running boards would seem to be about 5 inches lower than the chassis frame rails. We're considering installing a C channel or I beam along the length of the frame rail between the front and rear axle a little lower than the running boards. I don't know what others have done to address this issue... Do any of you others that have lowered your rides have a different solution ?
Old May 6, 2021 | 12:06 PM
56panelford's Avatar
56panelford
Why worry about it...
My panel I felt was too low so I lifted it a couple inches when I changed out the front cross member
Old May 6, 2021 | 02:30 PM
Waygonner's Avatar
Waygonner
How far off the ground are your running boards? When I built my first ‘56 with a volare front end we had to work the torsion bars a bit to get it so the edge of my front bumper wouldn’t scrape driveway entrances and such. I learned really quickly to take any obstacle at an angle so I could go one tire at a time. Never had issues with the running boards rubbing.
Old May 6, 2021 | 02:40 PM
jniolon's Avatar
jniolon
old and in the way
running boards won't be an issue , probably. My front gravel shield is 8.5" from pavement and had several scrubs... something I found that helped save the paint is a product called Sliplo..., it;s a tough urethane strip that self adheres to the lower gravel shield edge and takes the bruise for your paint... works well for me
https://sliplo.shop/
john
edjunior
Aug 10, 2021 06:07 PM
domdel63
Mar 29, 2010 09:18 PM
air5dad49
Jan 15, 2010 10:12 PM
orange51f1
Oct 10, 2005 07:37 PM
MooseHead Rider
Nov 8, 2004 11:19 AM
