78 F150 odometer issues
Old May 5, 2021 | 03:42 PM
bugsy1955's Avatar
bugsy1955
Hello Again!
The previous owner said when they rebuilt the engine they turned the odometer to zero. It now reads over 12000, but is not functioning properly. It does increase, but also seems to get stuck and freeze for periods of time. The speedometer seems accurate most of the time, however when on the highway the needle skipped around at times.
Suggestions?
Thanks!
Kevin
Old May 5, 2021 | 04:43 PM
agcoacres's Avatar
agcoacres
Verify the integrity of the Speedo cable and gears; verify that the cable is lubed in the sheath and us not kinked or binding; verify that the cable is positively seated in the Speedo head. If all of that checks out, but a new speedometer.
Old May 5, 2021 | 04:44 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Pull the trans end and insp the gear on that end. Then if you can not clean it up a bit, then probably time for a repop replacement speedo head.
Old May 6, 2021 | 08:35 AM
bugsy1955's Avatar
bugsy1955
Getting new dual exhaust today, so will work on it this weekend. Do you know the length of the speedo cable on the 78 F150? I was looking for a replacement if need be and looks like there are at least two lengths, 95" and 76"
Old May 6, 2021 | 10:06 AM
meangreen92's Avatar
meangreen92
I'm guessing that the longer cable is for 4WD, and reaching the transfer case.
ScorpionKing
54
Jan 12, 2021 11:37 PM
78LOTLIZARD
Ford Truck Parts for Sale
Nov 10, 2013 06:32 AM
mcmavv
Apr 17, 2013 09:39 PM
nd48463
2004 - 2008 F150
Jul 14, 2007 07:51 AM
walter1011
Oct 23, 2002 08:49 PM
