T98 Bell housing
You need one of these. They come on the heavy duty three speed in Canada. They are kind of hard to find up here. All the 4 speed crash boxes in Canada are similar to yours.
,Doug.You need a transmission case that looks like this (picture taken from another thread on this forum):
And, Mark has reported the T98 hogs head can be made from a T9 unit by boring out the hole for the front bearing retainer (machine shop job).
really appreciate your help!
Neale
thanks
Neale
This is my existing flywheel housing
This is the T98 I want to install
Neale, This T98 that you have will not work in your truck. This T98 is from a '53 or later truck. The front of the case on the T98 that you need does not have the ears to bolt it to the bellhousing. This transmission also does not have a mounting foot for the rear motor mount. here are some of photos of a T98 like you need.
Notice that there are no ears to mount to the bellhousing, as the mounting studs are inside the halfbell. The last photo is a T98 halfbell. Also note the rear motor mount foot. and that it is turned forward instead of rearward like the one on your T9. The T98 is approximately 2" longer than the T9, so your driveshaft will need to be shortened. Otherwise the proper T98 is a direct bolt in replacement for the T9. If the T98 that you have came from a '53, IIRC all the internal parts are the same as the '48-'52 T98s. In '54-'55 the input shaft was lengthened and '56 and later T98s had the helix direction of the gears changed so that none of the parts will work for the earlier transmissions.
I hope this helps, Mark Poley
Mark
My T98 came out of a 1950 F6 if that matters.
