Wet weather, MIL lit, P0136 code
Old May 5, 2021 | 05:51 AM
not hip's Avatar
not hip
2017 F250 XL 6.2 4x4
Drove to work this morning. Wet weather. Got off the highway and stopped for coffee and a bagel. Got back in the truck and MIL stayed lit on restart (Check Engine, not Wrench). Truck was acting like the TPS was faulty - would only roll forward at idle, surged for a few seconds, ran forward at idle, repeat...). I pulled over, restarted the truck and MIL stayed lit. Truck drove "normally" the rest of the way to work (about 1.5 miles). My cheesy OBDII scanner pulled "P0136" which is O2 sensor voltage.
It doesn't seem like an o2 sensor would cause this level of drivability issue.
What's your take on this?
Old May 5, 2021 | 06:04 AM
cpobst's Avatar
cpobst
https://www.ford-trucks.com/forums/1...dom-codes.html
My experience recently with some random issues.
Old May 5, 2021 | 06:20 AM
not hip's Avatar
not hip
Thanks, cpobst. I have already had one run-in with the connector back there by the spare tire. I have made two payments on the truck, so far. I guess every time I send a check I should massage that connector.
This is exactly what I was afraid of when forced to buy a "modern" truck.
Old May 5, 2021 | 06:22 AM
cpobst's Avatar
cpobst
Are you getting any codes pertaining to lost connection to modules?
Old May 5, 2021 | 06:32 AM
cpobst's Avatar
cpobst
Look in to getting an OBDII adapter and Forscan. It's very helpful.
Old May 5, 2021 | 07:43 AM
not hip's Avatar
not hip
The only code I'm seeing is P0136.
I intend to get the OBDII dongle and FORSCAN. Haven't done it, yet. Looks like I'm being pushed harder in that direction.
FiveOJester
Jul 19, 2020 09:07 PM
cranegrad
Jan 8, 2019 07:35 AM
redxl1664
Mar 17, 2018 05:55 PM
94WhiteF250
Mar 6, 2009 05:37 PM
intruder34
Modular V10 (6.8l)
13
Sep 12, 2008 03:39 PM
